SHUG
Here is the view when you arrive at the Crinan Sea lock
http://tinyurl.com/86mkf8f
Lat year we had the assistance of a Crinan Pilot which worked very well (she was very friendly and super efficient). Have done it previously with just 2 but hard work for both locks and singlehanded boat work if a strong crosswind, so 3 makes much easier.
Planning to go through again soon, and wondered - does the new assisted scheme replace the piLot, or what is the difference?
If you are short-handed for the Crinan (i.e. if there is only one or two of you) then let them know at Ardrishaig and ask if you can have an assisted passage. This is a new thing this year and makes life much easier. There is no charge.
- W
£50 charge on the crinan on top of the £124 passage fee, two can do the passage with ease in 3
days.
days.
in all honesty going around is better, only using the Crinan if the weather is bad.
Its ok in the Crinan but nothing to write home about, run down in places and in certain spots a pain to get a berth due to permenant berth holders. They really don't like you rafting (berth holders) its worth tthe passage just to raft up and watch them moan.
. . . once the taxpayers realize their money is being spent employing people to assist wealthy idle yachties there will be an outcry. .
It's not a lot of extra work and it helps prevent hold-ups by speeding up boats with 2-man crew.
- W
While I know you are an expert in this as in everything else but I have yet to see or hear any evidence of 'speeding up' but I accept that it is not the objective.
Misrepresented by the usual webcraft ballox!!
Could it be possible that courteous input to the canal authorities, suggesting BOTH repairs to the equipment and thanks for the assistance be prepared? Perhaps both could work for all.
Less than two hours from Tarbert to the Ardishaig sea lock, tides in Loch Fyne are less than 1/2 knot so ignore them, waiting pontoon outside, sea lock operates 09-1700 (19-00 at weekends now) keep well away from the pier as you pass the lighthouse coming in, if going through without any other boats go starboard to, then the ladders are just beside the cockpit. The exception is lock 14 at Crinan which is not lined and is like a quarry on that side. (the canal builders had run out of money long before they got that far) Assisted passage is a bit hit and miss and so far generally very slow but depends on who is on duty, if you have four on board put two ashore, one to prepare locks and one to close up after, if you are going through with another yacht share the work. Most crewed sailing yachts put the females ashore which is a bit perverse as the men on deck look as if they might get more benefit from the exercise. Going up, stern rope tight and nearly vertical, can then be left alone, bow rope well forward and manned, tighten as she rises, some people like to motor forward gently against the stern rope, but it NEEDS to be secure. Open the paddle on the side the front boat is on first, the current goes down the opposite side and circulates. Transit takes about 4-5 hours but most people spend longer. Good early morning transport cafe for bacon rolls beside lock 3 in Ardrishaig, good bar at Cairnbaan Hotel, pretentious hotel at Crinan which now does bar food. No diesel in the canal itself and Crinan Boats fuel pontoon can be awkward, you can get road diesel at the filling station you pass just after Oakfield. If you are stopping overnight at Crinan there is more breeze therefore less midges on the stbd. side berths above 14 and You will not get black smuts from the Vic 32 on your deck. Leave Crinan sea lock at the GMT time of HW Dover (low water) and you could be in Tobermory in next to no time, a bit later for Oban as it is only 3-4 hrs away. You will get 12kts. over the ground in the Sound of Luing. Note the shoals in the centre of Kerrera sound and go either side, it is well buoyed. Time to spare? Easdale is interesting and every yacht has to go in to Pulladobhrain at least once. I move my boat between Ardrishaig and Crinan regularly but much prefer the Campbeltown - Rathlin - Port Ellen route or C'town-Gigha if I have less time and it is not easterly, but then I am up and down the canal every day on my bike and I used to be a canal 'pilot'.
Guys
I am new to this area, I want to sail from Tarbert to Oban via the Crinnan, any passage suggestions will be gratefully received...
