omega2
If you have insurance then they will take care of it??
I'm not, the 73 wasn't a good motor , heard loads of them going this way. I'm forever advising my clients to get the injectors pulled and tested, A £100 nozzle can wreck the engine in 2 minutes.
This is the way most Volvo motors fail due to hosing injectors , takes the piston crown off in seconds.
Do you recommend having the injectors tested on all 10yr plus VP engines Paul ?
Bit more info . Water in oil and vice versa. Cylinder 6 seized. Am going out next week to try to make sense of it and find a way forward. Have found an alternative route for removing and refitting -need to find a spanish volvo paul! Any one know a good spanish marine engine repairer.
If you read the manual that's what it says, to be honest it's down to how honest the pump shop is wether they spin you a yarn that your nozzles are worn, it's usually low opening pressures that cause the hosing spray pattern to be poor and obviously the spring tension alters the timing advancing it which isn't good as you get detonation .
whats the cost of getting the injectors tested?
Actually, the Volvo agents here in Sant Carles de la Rapita have got a very good reputation and charge considerably less than Volvo in the U.K. They are old school type engineers and will always try to fix it first if they can. They are an old established family business and it is refreshing to see how well they look after their clients. I personally would highly recommend them and I know many more skippers here think the same. I have even been charged less than was quoted when there turns out to be less work to do or fewer hours. There are a lot of people around Sant Carles who talk a good game but be aware of what they can (or can't) do........
Regards
