Pleinmont
Ah nothing on a boat is ever as easy as you first imagine
Many thanks for the advice chaps - yes the mirror is just not possible and I also found the tiny angle mirror for the endoscope in the box but that didn't work either.
I reckon Plum's way is the only solution. Phone on a string pulled along the floor makes perfect sense.
I popped down earlier and managed to pull out the manky oil mat out from underneath (and in one piece).
Will wipe and dry the hull under the engine then try your phone technique. I keep the engine bay clean but I'd not ventured underneath yet - will feel better once it's all clean and checked the state of the oil pan.
Btw, there seems to be a range of air vent pipe lengths (and air filters)! Mine look to be halfway between both of yours.
My starboard ones must still be connected to the outside as they allow a little moisture in when running in a beam on sloppy sea with the wind from the side.
Not much but a cupful collects on the floor after a rough trip.
Same with the port side. That's odd some have been disconnected.
