Any Mustique owners here
Just secured a beauty
I’m looking out for any one who had one for experiences got practice and adviceVery nice
Yes spoke to Charlie there most helpfulwas that the one with Detroit’s EEDC?
did you speak to Mitchells?
Congratulations very nice boat!! ... you should have about 3T of machinery in there + gearboxes from my recollection... at 565 HP, the V6 DD's are a bit highly strung with the cooling system potentially being the weakest point. Please make sure that you get the rated full RPM (2,300 RPM) out of the engines when you have a clean bottom and when she does not that you throttle back correspondingly. The engines will run forever if you keep to a modest 1850 RPM on long cruise and if you do slow cruise, cut back to one engine and hold back below 1100 RPM to give some load, but not full turbo boost whilst keeping a reasonably hot combustion chamber..Yes spoke to Charlie there most helpful
The DD's will burn more fuel than a 4 stroke engine at idle due to additional mechanical friction (which takes up HP) but if in-tune they will give you comparable fuel burn with similar aged 4 strokes at the mid - high range RPM cruise.
If overheating, the weakest part of the engine is the seal at the bottom part of the wet cylinder liner of the engine and whilst the relatively low tech ECU is considered reliable, the unit is expensive to replace, so WD40 is your friend....
Never enter an engine room with a DD without a 1/2 spanner in your back pocket ... do a random test the bolts/nuts when you're down there and you'll quickly start to get familiar with the engines and which parts are doing what...
The engines will probably be "handed" with serviceable items (Filters etc) being accessible between the engines, and the engines will also in all probability be a Left Rotational Engine and a Right Rotational engine (was the way they handled the need for counter rotating propellers) which means that whilst most parts are interchangeable, the starter motor, alternator and ECU will differ between the two engines...
Good luck and congratulations with what looks like a very well maintained and good looking boat !
Thanks for the heads up here
The DD engines are very clean and responsive, the owner has had her from new and really lovingly looked after her
You mentioned running at 2300 rpm you thinking just for a blast out for a few mins ?
happy happy ?
A number of things here of potentials affecting cooling of engine ... but usually best to keep things simple to start ... but as you ask ...If in the event of over heating due to lack of raw water circulation could the impellers and pipe work be clogged ?
A little small for the sunseeker aperture good else where though4pcs Marine Boat LED Oblong Courtesy Light Stair Yacht Deck Clear Stainless 12V | eBay
better measure your current ones/hole size behind
Trying to find these bulbs in led blue
Guys
