pyrojames
That's an awful lot of sand she has stuck herself into fore and aft. 15.7 m draft I read somewhere.
One of the obvious advantages of a trailer sailer is that when this sort of thing happens you can just tow your boat home, Has anyone thought about trying to get a large trailer under her keel or weld wheels to her hull then transit the remainder of the canal by road?
Fantastic articleI get the 'bank' and 'bottom' effects, but since you're in flying form today could you pls walk us through this Yaw/Sway disequilibrium that sets the problem up?
Also, reading this article makes me wonder why these cock-ups don't happen more often as steering these giants seems very precarious indeed
Note to myself: Stick to the day job!
But doesn't that also make it easier to relinquish that small saving if there's any suggestion of a problem earlier enough?When the Americans ran the Panama Canal, they charged enough to maintain it; the Panamanians do much the same plus a bit to maintain a nation of 4.2 million people and build new locks, and indeed it is a by word for reliability, but the SCA take a different approach, having a nation of 100 million to maintain, and charge just slightly less than it would cost to go the long way round.
Think it’s above my pay grade and/or I once knew more about this than I do now and/or we used to talk about the bow and stern high pressure waves and the midships low pressure area. The effects are more logarithmic than linear; one moment you are fine and then if something changes you are not.
Using those terms, your bow wave will shove you into the middle of the channel or indeed right across it if you get too close.
My reading of the events is that the helmsman of the “Ever Given” was applying port helm to counter wind pressure and she was making quite a high speed (for the canal) to maintain rudder authority. Then there was a lull, which would only be apparent, in an enclosed wheelhouse, by reference to the wind speed and direction indicator. The ship probably started to swing towards the bank before the helmsman noticed that the wind had eased. He then put the helm the other way to correct the swing and as he did so the bow pressure wave threw the bows to starboard, leaving him no time to correct.
The worst case of a catastrophe caused by bank effect was the loss of the Houlder Bros cargo passenger ship “Royston Grange” in 1972. This was shortly before I started so it was much talked about. A horrible, horrible, accident.
STV Royston Grange - Wikipedia
I would go for pulling it out the reverse way it went in, but getting the tools to do the job on site may be a bit slowI am surprised that they have not used either compressed air to liquify and wash away the sand or even a water jet. The other thing they might do is to dig a big and deep hole in front of the bow but leave sufficient material to keep the canal out, when it's done just knock away the retaining wall allow the canal to flood in bringing with it most if not all the sand under the bow. Cheap and simple it may work it may not but I would have given it a go.
My guess is the insurance restrictions on who and what can be done carry huge weight as to the salvage.One of the props will turn the right way to scour the silt from under the stern. Have they been trying that I wonder, or is it ones of those "You can't do that.." jobbies?
Given that the real cost of further delay outweighs the cost of new shafts or even an engine..
Certainly the stern looks to be less embedded and might be easier to dislodge.
So...I am not a betting man but when does the clever money start going round the Cape?
Even on the very, very much smaller scale of a yacht in the Crinan Canal, these effects are noticeable. Get too close to the bank at speed and it's like trying to steer a wonky shopping trolley.Think it’s above my pay grade and/or I once knew more about this than I do now and/or we used to talk about the bow and stern high pressure waves and the midships low pressure area. The effects are more logarithmic than linear; one moment you are fine and then if something changes you are not.
