sailoppopotamus
My 30ft boat has a next-to-useless pin-stop mainsheet traveller so I bought an Antal traveller to replace it with. The track is supported across its length, but unfortunately follows the curvature of the cockpit in the vertical direction. While the radius of curvature is not too great (the center of the 1300mm track is around 30mm higher than its ends, so not more than 19m following Harken's formula) I think I will get much better performance and robustness from the system if the track is straight. So, having measured the profile of the current track, my plan is to use a friend's CNC to fashion a support to go between the track and the deck to take up the curvature. Any suggestions as to what material to use for this? Options are:
1. Wood, which will inevitably rot and degrade well before the rest of the system is due for replacement.
2. Acetal, which seems to have poor resistance to UV, leading me to think that it will also not last long.
3. HDPE, variants of which are apparently resistant to UV, but which is apparently very difficult to glue onto anything. Since it won't be glued to the deck, I would effectively be adding a massive washer between the track and the deck. This makes me worried about how the fasteners will cope with the loads involved, which will now exert a larger torque to both the fastener and the deck.
Any suggestions as to how to proceed? If possible I would prefer something that is black so that it doesn't stand out visually under the black track.
