ShipsWoofy
Before I left the boat I had to add some more packing to the stbd tube and greased both of them, port was fine but I had a problem with the stbd side. When I tried to squirt the grease gun, grease came out around the threads at the bottom of the nipple assembly (many occurrences of the word nipple to allow people to snigger).
Surprisingly I was actually able to unscrew (oh behave) the assembly to find it has become quite thin, it appears to made of mild steel, at least that is what it feels like, many years of grease has turned it black..
My question, as I forgot to measure the thread, is there a standard size for these things, I expect it to be imperial thread and diameter due to the probable age. I can of course measure it, but would like to try to source one today locally. I may even convert it to one of those screw down pots rather than a nipple.
Description, it is a tube about an inch long and about an inch diameter closed at the top with a grease nipple, fitted to a 1" diam shaft old style stern tube. Having never had a problem with one of these things I have never had cause to examine or even source one. Would say, a waggon axle use a similar unit, or will I need to visit a marine engineers.
Many thanks in advance.
