Brent Swain
N/A
I believe the White Star Line used to have a similar philosophy.
Search "Law of Mechanical Similitude."
No comparison between big ships and small steel boats , structuraly .
Boats built from steel are very well suited for some conditions, and for some among us who have a morbid fear of hitting a pointy rock or being attacked by a whale.
I know this happens-the poor fellow who lost his lovely HR off Biscay was in my house recently collecting a used genny I sold on the "For Sale" Forum. A collision with a whale loosened the keel enough to have leakage too severe for the pumps to cope.
Another, older model of HR with an encapsulated keel, perhaps a different outcome.
I would bet that more steel boats are being fixed up wordwide percentage wise than boats in other materials. My own steel boat requires serious work around the badly designed windows. I must make the decision to do the job properly or fake it up for sale-its a cheapy so not worth spending loads of time and money.
My reasons for believing the above are simple.
Seawater, atmosphere and steel equals rust!
Agreed, it CAN be easy to fix. It can also be a bloody nightmare!
You see, we are not all perfectionists who can build a steel boat that only needs two hours maintainence each year, unlike a certain superhero on this subject...........................................
I make ten dollars a book, a tiny fraction of my income. I am retired from building, and only post to help people out, and pass on what I have learned, in over 4 decades of steel boat cruising ,living aboard, designing and maintaining steel boats.First of all, I've never said that plastic is the only reasonable option. I can see the value of steel construction, but I can also see its limitations. I can also see the value of GRP construction, but can also see its limitations. Another way of expressing Robins point of view is to say that people who are so one track minded that they lose sight of all other peoples point of view and continue to trot out the same old arguments, have lost their argument a long time ago.
Secondly, going to sea on Ocean passages without a life-raft is not something I would be suggesting or recommending or contemplating for one millisecond. First of all it would have been illegal on some of the boats I have been sailing as they were commercially coded and inspected. Even without the legal necessity, you've no idea when a flange or weld is 'possibly' going to give way. Plenty of steel boats have looked really smart and good, but under the (multi layers) of epoxy, there's a failure about to happen when they hit that semi-submerged container and being without a life-raft on an ocean crossing is not something I'd contemplate. Its foolhardiness to the point of stupidity in my humble opinion.
Trotting out the occasions when GRP boats have sunk is not a compelling argument but Brent keeps trying. Give it up Brent. People know better because there are thousands of boats sailing round the world made of GRP that don't sink in the way you describe. I freely acknowledge the risk of sinking, but I manage the risk on my current boat in ways already described. For high latitude sailing, in remote places, a well found steel boat has a lot going for it. Its not without its potential problems, but some people don't seem to want to admit that!
What I am not prepared to do is for someone who profits from the sale of his books and work on steel boats to continue to post blatant misinformation and allow it unchallenged. If Brent produces a BALANCED argument, perhaps he will be taken seriously? On his current track record I'm not holding my breath.
Your suggestion that listing the advantages of steel is "advertising"suggests that I am the only one on the planet designing and building in steel. Is that why you equally "Advertise "plastic boats?
Your suggestion that, when someone who has 9 Pacific crossings in his wake ,most of it in steel, is still enthusiastic about the material, after 4 decades , is reason to reject it, is mind boggling, anti logic, as is your suggestion that one would be better off going by the advice of those with no such steel boat experience.
There are plenty of people who are just as enthusiastic about plastic ,wood , aluminium ,etc. Do you consider their enthusiasm for the material, reason to reject it?
That really doesn't leave you many options, does it?
If I believed other building methods, designs, and materials were better, I would use them, as would you.
I don't see you declaring that what you believe in is wrong, as you suggest I should.
Ok, I'll bite: Brent, if steel is so clearly head and shoulders above any other material, why do the big volume builders use GRP instead?
I’ve sailed in Brazil and don’t recall seeing many steel boats. I saw lots of GRP ones.
I’ve only been to truly remote places on larger vessels (built of steel!) and in Antarctica and the very S of America (Punta Arenas and then the Chilean islands going N on the Pacific side etc) I don’t remember seeing more than one or two Yachts. They may have been steel, but I don’t remember thinking, “Only steel boats down here!” Perhaps all the GRP ones had hit things and sunk without trace?
My GRP Sealord has given a good number of smacks to terra firma in that time... hasn't fallen to bits and sunk yet...
I have never seen single weld break on mild steel on small cruising boats, ,ever, including some horrendously bad welds. That is a plastic boat advocate's myth.
I have seen beautiful looking mig and tig welds break, having very little penetration ,but never stick welds. Tig and Mig needs flat calm, dry conditions, which is what makes a building site for an aluminium boat so expensive, altho one friend built a beautiful departure 40 in aluminium, outside, by picking only perfect conditions for welding . Took him a long time.
Stick welding is extremely forgiving of conditions ,and can be done anywhere, with no chance of weld failure.It is also the cheapest
A friend had a 35 ft steel endurance. He complained about maintenance, so I suggested he cut off all the welded down steel dorade boxes and deck boxes, drastically simplifying things ,making them out of removable stainless or aluminium. He said that drastically reduced his maintenance.
Simplifying can drastically reduce maintenance on a steel boat.
So we've got an advocate for no liferaft. (The law of mechanical similitude isn't relevant by the way.)
And a suggestion that stick welded joints never break.
And you expect to be taken seriously.
The only serious thing is the seriously big hole you're digging for yourself as your suggestions become more and more outrageous.
Yet you wee advocating welded on bits prevents corrosion that bolt on bits, as many commercial builders do caused were you not.or did I dream that bit of selective explanatory
Brent- still curious about why you think steel isn't adopted by the big volume builders?
