Split pin tape ?
Budgieboy
19 Mar 2012
Pacific 2019
Hi all ........ what is the best tape to cover your split pins in your rigging screws etc ? have tried a couple of different ones and they give up the ghost after a short while ....... :encouragement:
mjcoon
18 Jun 2011
Berkshire, UK
www.mjcoon.plus.com
sarabande
6 May 2005
try and find "silage tape". Thick, very very strong, and sticky, and resistant to UV.
All farm supplies shops.
NormanS
10 Nov 2008
Why do you need to tape them? On mine, the clevis pins are all put in so that no sheets etc can catch on the split pins, and the ones that stop the rigging screws from slackening off, are bent in a way that no ends can catch anything. IMHO it's better to be able to see them.
johnalison
14 Feb 2007
Essex
There is always the odd one that will catch a bit of line or something. I've just taped over the ones on my mast today in case the leech of the sail catches one. I use self-amalgamating tape. It lasts for a few years if it isn't abraded.
Slowtack
27 Feb 2007
Not sure about taping - I prefer to be able to see them and inspect regularly. I the sharp ends face downwards or inboard they are less likely to catch on anything imho
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
Quite so. The trick to split pins is to bend them out by 90° about half way along the exposed end, then bend again at the pin. Now the sharp ends are facing the pin, and cannot snag.
