TonyBuckley
Why don't you just ask them??
Yes that's sort of the idea lol
Not too sure I would copy speedseal's design, easier (legally and morally better too) to put my hand in my pocket.
It wouldn't be too difficult for even a rank amateur such as myself to turn up a replacement cover plate for the pump, incorporating the features of the original SpeedSeal. Just a very slight relief on the working face to match the original paper gasket thickness and a groove to hold an o-ring, selected to allow it to fully compress. The two drilled holes and two slotted holes can be drilled on a small drill press and slotted by hand if you don't have access to a mill.
Perhaps more interesting, or prone to errors if you like, would be to copy the design features of the later version with the separate wear plate. I suppose if you cut too much relief into the plate, some form of shim could be added to take up the slack, positioned under the wear plate. Bearing in mind the slight distortion visible in my pump's cover plate, I'm guessing the clearance isn't too critical sdo long as it doesn't bind or create a significant leak path.
Rob.
Sorry to resurrect an old thread but what equipment would you need to cut a circular groove in a steel plate?
My Johnson raw-water pump has, as standard, an O-ring, on the faceplate.
In fact with the Jabsco raw water pump on the 2GM you had to take off the pump to get at the faceplate - so I saved the money on a Speedseal and had a spare pump - which I have continued on the 3YM, because impellers last about 600 hours and seals about 1200. So a Speedseal is a solution looking for a problem (and very expensive into the bargain).
I just came across nylon slotted head thumb screws which I think I'll try.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290953726697&ssPageName=ADME:L:OC:GB:3160
Yes but as I said earlier - speedseal don't make one for my model of pump (Volvo MD1). So even Santa can't get one. Hence my question about making one.
Dinghyman, I don't see how speedseal can object to me making a new cover for my pump as they don't produce one to fit. I rang them to order one but was declined. I suppose there is insufficient demand for one to fit a 40 year old pump but I can still get impellers and seals for it.
Yes I can get the cover off and draw a pattern. What have you in mind?
I've got some of them and have used them for finger tight covers and they appear to be pretty strong so reckon stainless would be a better way to go, either knurled with a slot in or better still normal cap heads with a knurled outer to make hand fitting easier.
Speedseal sell their stainless hand screws as spare parts.
I use a smear of marine grease, which temporarily sticks the gasket to the face plate. Saves a lot of faffage!
