Seastoke
Just a quick one , I have a small panel that charges my security camera on the boat 6Volt 3.2Watt, I have a spare panel the same, so can I double up the panels.
Yes.Just a quick one , I have a small panel that charges my security camera on the boat 6Volt 3.2Watt, I have a spare panel the same, so can I double up the panels.
3.2 watt.What output is panel?
3.2 watt.
Just a small camera.That's a brace of really quite tiny panels. What do you want to do with both of them joined together ? Are you familiar with joining panels or batteries in series and/or in parallel ? With low voltages, long cable runs between the panel and the machine or motor can absorb ("waste") a lot of energy. If you can give more info on the layout , it would be useful.
Yes, if you wire them in parallel.Just a quick one , I have a small panel that charges my security camera on the boat 6Volt 3.2Watt, I have a spare panel the same, so can I double up the panels.
6 volt and are matched to the camera
Yes you can ...... Wire them in parallel and your be fine.Just a quick one , I have a small panel that charges my security camera on the boat 6Volt 3.2Watt, I have a spare panel the same, so can I double up the panels.
