purplerobbie
What is the best type of solar panel for a live aboard boat.
Don't know much about them so any help would be appreciated.
As far as I can tell: Cheap ones.
We'll be moving aboard in April and heading Med-ways. We're in the process of fitting three 100w eBay specials. I figure if one is damaged, they're cheap enough to replace.
Rigid panels, if it is practical to fit them: more bangs for your buck and far more durable than semi-flexible, which are especially prone to UV damage (learnt the hard way).
We use Kyocera in rigid frames on gantry, can be tilted fore/aft. Hard to say which are best/worst make as too few reports of failures.
I have Like and see lots of Kyocera panels.
Kyocera specifically do not recommend their panels for marine use. Which is a pity because they have by far the best solar conversion rate and I can get them from the local importer at very economical prices.
That's very odd. When I bought mine around five years ago they were the only ones that were recommended for marine use. As you say, the current datasheet does not actually mention marine use but the oil and gas line suggests corrosion resistance. http://midsummerenergy.co.uk/pdfs/kyocera_kd70_70W_solar_panel.pdf
However, mine show absolutely no sign of any degradation.
