soft shackles
john newton
15 Sep 2012
I thought that this was just what I did to avoid the expense of metalware but the term seems to recur here. What exactly is a soft shackle? I just tie a loop, sometimes a coil, usually with a fisherman's bend.
john newton
15 Sep 2012
I might have known it's something you have to buy. What's the difference between it and my loop made with a fisherman's knot? I get the strength I want by doubling up whatever line I'm using.
The device in the photo seems to have a stopper knot threaded through an eye splice, it sounds the sort of thing I could make sitting on the deck doing my Peter Duck act with my sailmaker's palm ( I don't smoke a pipe) although I find myself increasingly reluctant to do tiddly things.
raggy
9 Mar 2010
Its not something you have to buy. They are relitivle easy to make with a little practice. All you realy need is a fid. Best to practice on some cheep single braid before going for the dynema.
Clicky
UncleAlbert
19 Jul 2012
Maldon
I made a couple of these last year and used one to affix genoa sheets to clew. Worked really well, never showed any sign of undoing or wear and helped a lot with allowing the sheets to get past the baby stay during tacks as theer is less bulk.
Its also less painfull than metal work or knots giving you a slap on the head when the sails flogging and you need to sort something out on the fordeck!!!
Thoroughly recommend having a couple on the boat for other attachment purposes.
Unc
onesea
28 Oct 2011
Solent based..
Easy to make and effective and do not need to be Dyneema just strong enough for the job.
Once upon a time you would use a man rope know and splice in 3 strand rope. Or a toggle to do similar.
ghostlymoron
9 Apr 2005
Shropshire
Does anyone know what Amsteel is?
Rob
Rob, Haven't you heard of Google?
AmSteel® is a nonrotational, Samthane-coated 12-strand single braid that yields high strength and low stretch; equivalent to wire rope with one-seventh the weight. In addition, the product is flexible, spliceable, and resists flex-fatigue and abrasion
http://www.samsonrope.com/index.cfm?rope=190
ghostlymoron
9 Apr 2005
Shropshire
The advantage of soft shackles is that you can easily undo them just like a hard shackle.
rob2
23 Aug 2005
Hampshire UK
OK, very good, but you left out saying that it in fact Dyneema. The part quoted is typical US, meaningless marketing sh+te (I ask you - Samthane!). Sorry, but it was the simple fact that the link was so well written and made perfect sense other than that the material is given as a brand name which led to my slightly sarcastic question. ;-)
Rob
ghostlymoron
9 Apr 2005
Shropshire
Rob
Dyneema is just another brand name. A chemical formula would mean nothing to me as its presumably a long polymer.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
A very long polymer: Ultra-high-molecular-weight polyethylene (UHMWPE, UHMW) is a subset of the thermoplastic polyethylene. Also known as high-modulus polyethylene, (HMPE), or high-performance polyethylene (HPPE), it has extremely long chains, with a molecular weight usually between 2 and 6 million. Source Wikipedia
Foolish Muse
27 Dec 2012
I made some myself. Very easy with a fid. For the knot, I didn't use a fancy knot. I just did a half hitch and dipped it in glue to hold. Works fine. You notice that the eye of the soft shackle is very small when closed. This is important I think.
Neeves
20 Nov 2011
Sydney, Australia.
Soft Shackles, loups etc have been used by rock climbers for decades, they were boringly called slings (and were knotted, not spliced) - its odd they took so long to reach the marine industry, maybe it was the introduction of Dyneema that was needed. Rock climbers used tape, hence my use of tape (my idea is hardly original). There are a whole host of other rock climbing devices with marine application, jumars, ascendeurs (or the prussik knot) to climb masts, abseiling brakes as boom brakes, climbing harnesses instead of bosuns chairs (and when I climb the mast I use climbing boots - more comfortable than deck shoes - but a personal thing). I now only use a climbing harness. There are others (and some might not be marinised, or salt water compliant) - but I forget (and I do not have pictures - I'll try to get round to it, never thought it would ever be of interest). In rough weather I had wondered if a helmet (climbers, but bike would do) would be useful should I ever need to go up the mast - but I never went further than wondering. There might be devices that cavers use - do not know.
