shower drain pump
the drain pump fitted at present is obviously too small it is a whale in line, tried fitting a slightly larger one but still will not pump the shower drain. Tried a non return valve also as water returned when pump stopped. It has to pump about 3' & up to the outlet skin fitting.
Anyone got advice/suggestions re what type of pump can i get to do the job, i can't think of any way forward myself.
Many thanks
Col
14 Oct 2001
Berks
No expert on this, but mine has got a sump that the shower drains into. When the water reaches a certain level, a float switch operates a small bilge pump all contained within the sump.
Sump has a gasketted lid that contains smells, but can be removed for servicing, so it doesn't matter if sump hasn't been completely emptied- It isn't going to leak!
Works for me. Hope this helps.
<hr width=100% size=1><A target="_blank" HREF=http://www.arweb.co.uk/argallery/colspics> Cols Picture Album</A>
stephenh
6 Jan 2002
London UK
Even the smallest whale pump should be adequate.
However shower pumps are the most vulnerable because of hair and soap.
One single hair can wind round a flap / nonreturn valve and render it useless.
Try :-
stripping pump and checking for hair ( even one !)
fitting a fine inline filter and cleaning this regularly.
Hope this helps
Stephen
stephenh
6 Jan 2002
London UK
if my previous post is the answer then the ultimate solution would be No 1 haircuts all round for all and any who come aboard......
gtmoore
8 Jan 2002
Croydon
I have a Whale Gulper pump fitted directly into the waste pipe. It's a diaphragm type pump. Despite the adverts I needed to fit a course filter with it. It is quite happy to run dry and will pump air and water. I just switch it on before jumping in and switch it off when I'm finished.
Details of it are at <A target="_blank" HREF=http://www.whale.ltd.uk/marpro/gulp220.html>http://www.whale.ltd.uk/marpro/gulp220.html</A>
HTH
<hr width=100% size=1>Gavin
Spacewaist
1 Oct 2002
UK
blog.mailasail.com
Dont s'pose theres already a filter in this system? These symptonms sound like mine behaves when the filter is blocked.
<hr width=100% size=1>A pontification from the Panjandrum of orotund bloviation AD2002
