Mr Googler
Cant see that company not knowing what they are doing
That’s a pity...because they would then have a new size range available without having to pay for R&D....probably the company is overwhelmed trying to ramp upWe enquired about having a set of these custom made for a clients 75ft mobo. Initially they said $40k for R&D and another $40k per prop. Our client was willing to go ahead but they changed their mind as didn't want to do a one off!
They did indeed, the general concensus is that the normal prop they compared against in those tests was not optimal for the test boat /engine hence the sharrow prop showed significant improvements in fuel economy and top speed when compared to that sub optimal propBoattest.com are very upbeat about Sharrow and have published numerous articles and test...all with very satisfying results
True...the other scenario is they have invested in itThey did indeed, the general concensus is that the normal prop they compared against in those tests was not optimal for the test boat /engine hence the sharrow prop showed significant improvements in fuel economy and top speed.
True...the other scenario is they have invested in it...but those who are not satisfied with their current setup are the logical first customers for Sharrow..so perhaps not surprising
I remember trying to find a prop cage or tunnel to protect my outdrive in a river…they didn’t exist and when I thought about making one all the experts I could find said ´cavitation’ and other warnings.If they were any good they've have been adopted by the major manufacturers years ago. As they say, if it sounds too good to be true, it usually is.
You were looking for something like this??I remember trying to find a prop cage or tunnel to protect my outdrive in a river…they didn’t exist and when I thought about making one all the experts I could find said ´cavitation’ and other warnings.
A few years later…someone brought one to market ..and not only did it protect the prop but it actually increased efficiency.
So challenging accepted wisdom is no bad thing
Or even better this, with Azipod.You were looking for something like this??
You must be joking. Those things run on cleavers, which Sharrow props aren't even remotely meant to compete with.An Apache OB on Yam 350 s or Evenrude 400 s running poker runs ….sure go ahead start wining Sunday afternoon races.
Azipods are quite popular on the canal and river barges on the inland waterways of EuropeOr even better this, with Azipod.
Eat your heart out Volvo Penta, this is the real thing, which was already tried and tested (successfully!) well before IPS was still on the drawing board...
Oh, and it's actually installed in a pleasure boat of relatively human size, at 65'.
