Shackles
Rum_Pirate
23 Aug 2004
A tiny Island, Caribbean
Find it amazing that shackles while they have a pull on them always (if not moused) have a way to unloosen/undo especially those underwater.
They NEVER seem to tighten up.
Never one pull tightens up, then say next pull loosens etc.
It would be reasonable to think that on average it would do so.
Anyone got an explanation as to why?
boomerangben
24 Jul 2003
Isle of Lewis
I suppose that as you tighten the pin, the threads deform elastically. With the geometry of the thread, there is a tendency for the spring effect to act to undo the pin. However friction is sufficient to stop it happening. But repeated loading cycles is going to cause micro deformations and since there is less work required to undo the pin than tighten it.
It is one of the reasons we only every used bolt type shackles in underwater construction
William_H
28 Jul 2003
West Australia
The problem in a mooring is that the boat is constantly tugging possibly every 2 or 3 seconds for 24/7. The variablitly I think of what is probably nearly symetrical tighten and untighten on the pin still gives the chance of total unscrew. All exacerbated by wear of the threads with the movement. In the end they do undo themselves so beware. ol'will
Rum_Pirate
23 Aug 2004
Perhaps you only notice when it loosens because of the consequences?
I always put a wire mousing on the shackles.
I usually use monel wire, which I also use when fishing.
American Fishing Wire Monel Trolling Wire (Single Strand), Bright Color, 30  Pound Test, 600-Feet (Two Connected spools)
PS The undoing incident referred to in the OP was relating to a friend's installation. Honest Gov.
KREW2
20 Jan 2005
Dorset
We do not use any shackles in on our moorings, except for the pickup buoy. The riser has two larger egg links on each end of the chain, this is reeved through the ground chain. the same goes for the bridle. These are reeved back through the large egg link on the riser, eliminating the need for moused shackles.
William_H
28 Jul 2003
West Australia
They say to never use stainless steel shackles underwater, especially salt water, and never use clear/white cable ties as they degrade in sunlight.
Use black ones.
I have had 10mm stainless steel shackles ( moused with monel wire) in my mooring for quite few years now. However the rest of the mooring gear is SS as well. Starting at the top with a mandatory authority supplied buoy with ss swivel built in, I got some SS chain which does loop through a railway wheel of iron as the mass. All good. The problem with SS is whenb it contacts black iron the dissimilar metals creates wear damage in the iron. ol'will
PabloPicasso
12 Feb 2010
i had a plastic wire tie fail recently when used to seize a shackle
I use two, usually black, cable ties passing in opposite directions to address the issues of one failing.
Shackle undereater failures are likely often due to corrosion. This may well occur evenly{ish} over the whole shackle, but the threads fail first as there is less material there. Then the pin falls out releasing the shackle and anything dependent on it.
Grease the threads with a water resistant grease to reduce corrosion and make it easier to undo when the time comes.
