The Gas Spring on my Selden Rod Kicker has failed.
The plastic fitting on the piston end unscrews. On the cylinder end the plastic fitting rotates but doesn’t unscrew- How do I remove it?
It sounds like the metal insert within the plastic might be spinning.. However you get it off, I would replace those plastic end fittings..
Have a read of my comments in this earlier thread, especially try the link in my comments to the story warning about what can happen if the plastic part fails due to old age / brittleness.. Selden Rodkicker gas spring
I made the mistake of buying from SGS Engineering and will never buy anything from them again. The strut they sold me was faulty and their follow-up customer service was appalling.
