C
Chrusty 1
Let me guess the punchline...
...you've been fingering dykes ever since?
I think a lot of people have beer goggle syndrome when it comes to iron sh*tehawks.
There is a closer connection with Stuart Turner engines than you think. I was partly responsible for the SD110 - I like to think for the bit that worked, that is the idea not the execution! The first iteration was intended to be a replacement for the ST 1.5hp beloved of the launch owners in the "Parkstone set" in Poole who kept their yachts on the Wych channel moorings before the days of the yacht havens.
From there it grew aspirations to be a low cost inboard for small yachts such as the Coribee (which I guess is what blueboatman had). However his description of how to get it (hopefully) to work came about because there was no money to develop the features I originally proposed which would have made it a good engine - particularly when the later powerhead became available.
My redundancy money from Seagull (not connected with the SD110!) bought me a boat with a Stuart Turner 8ME which I kept (the engine, still have the boat) for nearly 10 years. Similar skills needed to get it to work, but I found conversion to catholisism necessary and reciting the catechism while on my knees helped!
Beer-goggles and Sh*tehawks? Are we at risk of another digression, here?
You mention 'recycled material' as if that was a good thing ...
Re-cycling of any material is energy intensive, and creates it's own pollution in the various processes it uses. At best, re-cycling is but a band-aid to be used until a better solution is found - but it has become a quasi-religion for those of limited vision, and as long as they continue to worship at the altar of re-cycling, then they will be able to carry-on with a guilt-free polluting lifestyle.
Better by far not to need any re-cycling - and that's what the Seagull mindset is all about. But unfortunately, the small quantities of pollution from a Seagull are visible - and that makes them an easy target for those who only react to what they can see - but do bear in mind that pollution from a Seagull is fully biodegradable.
"But they burn oil" I so often hear people say, and yes they do ... along with the countless millions of diesel engines churning out their oil-based fumes hour after hour, day after day, all over the world. The only difference being that the Seagull's emissions are visible, and offend those who have taken up this absurdly biased environmentally tokenistic hue and cry.
Yes, by all means ban the Seagull, then you can go on crapping all over the world without any guilt. Bought any new electronics recently ? What's the environmental story there then ? Washed any man-made fibres recently ? Only now is it coming to light that thousands of tiny micro-fibres are released from each garment during the washing process, and these are entering the marine food chain at it's lowest level ... and these are NOT bio-degradable - now there's something to really worry about.
Yes - by all means gaze down into the outboard's test tank and get yourself all excited by the scum - better then to not look into your wheelie bin, or those of your neighbours, and most certainly don't ever look at the waste water coming out of your washing machine ... for there you'll find real causes for concern.
Still - criticising Seagulls always makes for good press, and if you're a journalist, that's your real target after all - getting yourself into print.
Well, it's just the kind of response to be expected when someone doesn't have a very sound argument underpinning their agenda.That's a bizarre interpretation of what Electrosys posted!
hi dylan---with respect you are making a lot of fuss over what is in worldwide pollution terms is a miniscule amount of pollution----in the latest posts you will find someone asking what 50 foot --3/4 of a mile a gallon boat he should buy----if you are really concerned about the planet perhaps a bigger and better target for you----regards lenten
I suspect that this problem of oil being sprayed out of a Seagull is rather overstated. Indeed it may happen more if people try to run their Seagulls on a smaller ratio without changing jets/needles - that would make the mixture too rich and you may indeed get a little oil left unburnt.
I don't need to look at the web. I merely pointed out that the problem is rather overstated, and attempts to lower the amount of oil in the mix can make it worse.
You do make it sound as though there's a fire hose amount of oil gushing out all the time over the children paddling nearby.
I probably get through maybe half a pint of biodegradeable 2 stroke oil in my Seagull every year, and the majority of that gets burnt. I hardly think a couple of fluid ounces amounts to environmental armageddon compared, as I posted earlier, to the environmental manufacturing costs of a brand new outboard, be it 4 stroke, 2 stroke, steam or electric.
Ive got a question about all this oil from 4 stroke engines that gets changed on a regular basis all over the world.
from cars ,motorbikes ,big ships,our little ships,trucks etc etc
now thats a hell of a lot of old used oil!
now what happens to it?
