Bouba
Getting the man out...and the boat out simultaneously is the problem. He is busy this time of year...and I’ve been let down before. I know my limitations... and much of the work on the boat is done by professionals....but I do have a strong DIY input as well (with the collective help of the forum.....who I love dearly despite them being a bunch of argumentative codgers .....their only real fault is, if you show them a rabbit hole they all dive right inSurely they will lower it on blocks but with the slings still in place, doesn't sound right leaving it in slings overnight without any additional support.
Since there are some unknowns in removing the old unit, I would just get the repairman to do it as he will have everything he needs and knows what to do if there are problems. If you make even a slight mistake like disturbing the thru hull seal, it will start weeping when back in the water, then you'll have all the expense of another liftout.
I do like your problem posts on this forum, some of the responses are quite informative.
