rigpigpaul
Hi All, what tools do you use to scrape off shell on the hull. I was thinking of an ice scraper which I use on my car windscreen.
thanks in advance. RPP
...I was thinking of an ice scraper which I use on my car windscreen.RPP
Thanks for the replies. I will be in the water, so I will go for the hand held metal painter scraper.
Hi All, thanks for all the advice. ,I have cleaned the hull on both sides about 1.5m below the water line. Now I want to clean the keel and prop. I will use a couple of ropes as Roberto suggests. I would like to stay under water to clean the prop. I thought of extending my snorkel with a hose and making or buying a weight belt. What are your thoughts?
Be careful with the snorkel and hose. If you inhale and exhale through the tube you will never clear the used air and just be re breathing it. Dependant on the length of hose of course. If you choose to use this method, the hose needs to be strong so it doesn't collapse with the water pressure. Weight belt makes it a lot easier.
