Sanderling_
Dear all,
I have a VP 120SD and I recently started to have a problem in that I find I am unable to get out of reverse without diifficulty when the engine has been running for some time. When cold there is no problem in moving from reverse to neutral however when it is warm, I get stuck in reverse. The best solution being to stop the engine and then put in neutral beofore restarting, however, this takes time which is not always available.
The Morse control mechanism has been changed (broke the lever first time it happened!) so I think I can exclude this, the correct grade of oil is fitted and is at the correct level. I have tried to adjust the cables without joy.
Apart from the obvious 'sail more, motor less', does anyone have any idea as to what the problem is and what the resolution may be?
Thanks,
Tony
Thanks,
Tony
