nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
My Lofrans Tigres [sic] uses SAE 90-140. Searching on eBay shows no results, so is this now called something else?
, so any suggestions on a recommended type or brand for this application?
I also have a Lofrans Tigres and I use EP90 gear oil.
Don't quite understand 90 - 140 does that indicate a multigrade like engine oil. Now engine oil is subject to head that is very unlikely in a Lofrans Tigres.
The pic of the container of the Valvoline Gear Gard EP 90-140 (GL4) that VicS posted only shows SAE 90 so what does 90 - 140 realy mean.
... in a windlass it will nearly always be close to the cool 90 end so I'm sure that a 90 grade oil will be absolutely fine.
Thanks Richard, it seems that at least one version of the user manual specifies SAE90.
So is this the same as EP90?
Not quite EP means extreme pressure so IMHO is better than straight SAE 90 which just specified the viscosity of the oil where as EP can stand extreme pressures up can get in some gears
I agree.
EP (also called Hypoid) used to be more expensive that straight 90, but it's now the same price so I always use EP even in non-hypoid gearboxes.
Of course, if the manufacturer specifies EP then you probably have hypoid (helical cut) gears so you should definitely use EP.
There has been some discussion about whether using EP in some old design straight-cut gearboxes might cause problems although I'm not sure that these problems have ever been observed in ordinary usage conditions and, in any event, most of the drive trains we are talking about on the forum are probably too modern.
Richard
Thank you, I've always wondered what hypoid meant.Of course, if the manufacturer specifies EP then you probably have hypoid (helical cut) gears so you should definitely use EP.
I think you will find there is a worm drive. Dont know if that requires an EP oil or not. Of the two Valvoline oils I suggested earlier one is a GL4 oil and one is a GL5. If an EP oil is preferred should the OP choose GL4 or GL5
As if I wasn't confused enough!![]()
Diagram here confirms worm drive.
A little clarification on the viscosity. Multigrades have the format 15w-40, not 15-40 or 15/40. Are you sure that if your manual says 90-140 it is not giving you options, dependent upon duty/temperature/model?
What do you guys think?
