Rubbing strake replacement
Oletimer
4 Sep 2018
Wolverhampton, UK Boat: Gosport
I think it's time to replace the rubbing strakes on my little ship. I have no idea as to the wood but presume it could be Oak or similar hard type timber.
pandos wanted a picture and now that I can post one, it'll be a pleasure:
Not sure of the clarity, but can you guess the wood I'm working with?
George
Oletimer
4 Sep 2018
George
Looking at the picture the quality isn't brilliant, I'll try to find a better one.
johnlilley
30 May 2001
South Dorset/moored Poole/lay up Wareham
www.seasurveys.co.uk
Almost certainly not oak, most likely to be either afrormosia, iroko or maybe mahogany (sapele). Obviously you can use teak but that will be prohibitively expensive and unlikely to have been fitted originally. If it is dark brown then it will either be iroko or afrormosia, if it is red when you plane it back it will be sapele (mahogany look alike)
scruff
2 Mar 2007
Over here
As an alternative, you can now get new synthetic teak trim tor toe rails / rubbing strake. It may be a fairly effective use for it bearing in mind the abuse a rubrail can take.
PuffTheMagicDragon
Difficult to say from the picture. When replacing the old Teak rubbing strake/toe rail on my boat (a Wauquiez Centurion 32) I didn't even bother with finding Teak. I opted for Iroko - much less expensive and just as good, IMHO.
ghostlymoron
9 Apr 2005
Shropshire
Judging by the age of the boat it could be mahogany which is now replaced with sapele. My 1970s Leisure was that but was replaced with rubber bumpers which were were more practical. Available from Seals direct.
Oletimer
4 Sep 2018
TBH, I don't know which way tom go. I would like to keep it as close as possible to 'looking right' so no super duper technology that looks 'too new' especially nothing that obviously looks 'out-of-place'.
I do need to replace the wood, but I think I'll keep with wood. It just 'feels' right to me . . .
do think I'm getting too old, my daughter thinks I don't take 'modern' corners very well. :confused:
Fr J Hackett
26 Dec 2001
Saou
Leave it alone it doesn't look to bad at all unless there is some damage we can't see. After all it's a rubbing strake it's supposed to get worn and be sacrificial.
coopec
N/A
23 Nov 2013
George
When I went to my supplier Importer of timbers for my yacht I asked him for timber to match my sample. He deliberated for quite some time and mentioned several timber names before deciding it was a particular type of timber.
From then on I've picked timber that matched my existing timber as who is going to notice the difference when an expert has difficulty naming a particular specie of timber?
I'm wanting to add a rubbing strip as I've never considered the timber around the gunwale to be a rubbing strip. I'm now considering a synthetic section glued (Sika 291) to the hull about 3-4 in. below the stripe. Would that be considered workmanlike?
PuffTheMagicDragon
What would you do with it?
More than the rubbing strake, I would give first priority to re-positioning your stern light. The arc of visibility is impaired by the transom-mounted rudder and this renders the light non-conforming with regulations.
Of course, if you opt for an all-round light it has to be higher, at least one metre higher than sidelights.
coopec
N/A
23 Nov 2013
Unless there is damage or rot we can't see, I would have a go with a heavy sander to get the weathered surface off .
I'd agree with that but I hope it wouldn't have to be too heavy. (And finish it off with a couple of coats of Cetol) Nothing is perfect....
lw395
16 May 2007
I would not do that.
It won't be very effective at fendering and it will create a lot of drag as the boat heels.
