Rig tension.
IanCC
14 Oct 2019
30' masthead sloop rig tension. 2021 rigging.
I have read the books, done the 2 metre tape thing. But then after a few months it's not as tight as it once was. So, do i slack it all off and start again with the 2 metre tape, but now with pre stretched wire, or what? . The books are silent on this.
Thanks for all input.
dunedin
3 Feb 2004
Personally I have no idea what the “2 metre tape thing is”. But unless I was racing (in which case use proper tension guage and boat specific tuning guide) I just have a heave at the shrouds to assess tension. Get them pretty tight by feel (half inch or so movement), then go sailing in a bit of a breeze, sheet in tight and check the lee side doesn’t go too slack. Not too much science.
IanCC
14 Oct 2019
Fair enough.
johnalison
14 Feb 2007
Essex
With modern double-spreader rigs on larger boats I think that correct setting-up is necessary for the safety of the rig as well as optimum performance. With smaller boats and simpler rigs this may not be absolutely necessary. On my Sadler 29 with its masthead rig I would just tighten it until it felt right and then check on each tack when sailing, but I accept that this does not reach what would be considered ideal. If the rig is slack after a short time, either the wire is stretching or the boat going out of shape. On my current boat the rigging was checked by a rigger after a few months and has had hardly any adjustment after many years.
coveman
10 Apr 2016
Selden do a useful guide for all rigging types that may be helpful - google "selden hints and advice".
VicS
13 Jul 2002
Then see the Selden Hints and Advice pdf mentioned by Coveman. It is described in there as the "folding rule method".
They also describe how to check in the way you describe but with a little more precision, ie at a 20 degree angle of heel.
dunedin
3 Feb 2004
But my point was you probably don't need that much precision for a cruising 30 footer. I haven't needed that in a quarter of a century sailing - and we still overtake most boats of similar size upwind, unless they have black sails.
bignick
10 Aug 2011
Poole
The intention of the “folding rule method” is to be able to set a known tension in the wire, without having a tension gauge.
You still want the original intended tension, for the sake of the rig, so if you aren’t able to borrow a gauge then just start over again.
Daydream believer
6 Oct 2012
Southminster, essex
Another point about correct tension, with double spreader fractional rigs, is that one has to set up with a degree of pre bend, to avoid mast inversion. This could be catastrophic. Just setting up to avoid a bit of slack leaward shrouds up wind, is not really sufficient. There is a correct balance between each set of shrouds. Giving them a "twang" is not the way forward. Personally, I feel that- for the cost involved- a rig tension guage is an investment, which will last years.
Chiara’s slave
14 Apr 2022
Western Solent
Has your rig stretched, or has your boat bent?
Ours needed adjustment a few months after renewal. That is the diamond stays, we have, and regularly use, a tension gauge. The diamonds are where our pre bend is controlled. As DDB says, modern fractional rigs all work like that, ours being a tri is no different in principle. The rest of our rig is tensioned with the running backstays according to wind strength, simple with dedicated winches.
Bobc
20 Jan 2011
Yes, but we're not talkjng about your rig, we're talking about a simple masthead rig, which shouldn't need re-tensioning.
Bobc
20 Jan 2011
It plainly does. I'd start again with the same method. Why you think not taking up the stretch is a good idea is beyond me.
It shouldn't be tight enough to stretch, but quite often if the rig has been over-tightened on an old boat, the boat will bend, making the rig slack. If you just re-tighten the rig, the boat just bens more, until you do some proper damage.
The wires on a simple masthead rig are simply there to keep the mast in column. There is no pre-bend, and the backstay simply tensions the forestay.
Chiara’s slave
14 Apr 2022
Western Solent
Er, yes. And if the rig is slack, a deck stepped mast can jump off it’s step, and a keel stepped mast can over stress the deckwhere it passes through. Correct tension, not over tension, is the purpose of owning a gauge.
Bobc
20 Jan 2011
One other thing for the OP to consider, is that every time you physically stretch stainless, you weaken it.
fredrussell
24 Mar 2015
Apologies for going a little off topic, but my mate has just had the standing rigging done on his 31ft double spreader rig. All work done by a well regarded rigger. I was surprised to find that his intermediates are pretty loose. I would estimate you could deflect them an inch each way without any great pressure (with your little finger, say). I’ve always thought they should be tight enough to only show slackness slightly when hard on the wind in a good breeze. That’s how mine are anyway.
Bobc
20 Jan 2011
The correct tension won’t result in extra stretch. If he’s winding it on too hard, possibly. But again, a gauge will tell you that.
But if it's gone slack and the boat isn't bending, that suggests that it's been over-tightened and stretched.
