Replacement LED bulbs for Nav lights
Peter
31 May 2001
cumbria
My nav lights, Hella, are fitted with the original incandescent bulbs. Want to upgrade to led bulbs. Do I use a white led for all. Or do I use a red led bulb for port, green bulb led for starboard, and a red/green/white sectored for tricolour and keep the orginal coloured light lens in place.
Not sure about Hella but for Aquasignal one should use a red LED behind a red lens, green behind green and white behind white (probably cool white instead of warm). A note of caution: incandescent lamps (bulbs) have a single vertical filament to match the cut-off angles of the lens unit; using an LED lamp might well result in the light pattern angles being all wrong. This could be much worse in a tricolour, with or without a tricolour LED. Ask Hella.
Doesn't show up brilliantly in an animated gif, but this flipping between white and green Cree 503 LEDs behind the green section of a tricolour >
Green is green and white is blue :)
If you really want to get into it the colour definition is in an IRPCS annex so if the LEDs have a decent datasheet you can graph them and see if the LEDs lie within the specs.
http://www.sailtrain.co.uk/Irpcs/annexi.htm
https://www.desmos.com/calculator/dv72wa4rr8
When I replaced the incandescents with led in my Hella 3562 port/starboard/stern light I found the bulbs were modified from the standard festoon type which made the replacements twice as expensive. There is a metal collar on the bulb which is soldered on however, it can be unsoldered and slipped onto a standard bulb which is much cheaper from Boatlamps. It's important to get the correct length but unfortunately i can't remember what it is.
Having just done exactly this, I fitted "warm white" to the Hella lamps at the front and rear, after transplanting the two prongs, and they are excellent. I did not fit the "all round" bulbs boatlamps suggest as 60% of the light/power is wasted illuminating the back of the fitting. The result is excellent, much brighter than before.
I fitted a "sectored" LED to the Aquasignal masthead, and it is excellent.
I was ready to be shot down in flames over this but unless someone's checking with a spectrometer I reckon we're okay.
As I said in post #4, there are two aspects to this; one is the colours (that seem to have been resolved with the right coloured LEDs) and the other is the angles. As an LED lamp is wider, for want of a better word, than the original vertical singe filament, it could be that the legally-required display angles are exceeded. A mere academic point? In the (admittedly unlikely) event of a night collision, wait for the lawyers etc to crawl all over the boat looking for technicalities. Some LEDs are fitted with the appropriate blinkers (again for want of a better word) but others are not.
I was told the same thing by the guy at the store. A white LED does not shine red or green through a lens, when looked at by more than 10 feet away.
The idea that the colour of light changes as you go further away is a very peculiar one, and I can't think of any science which would support it. Neither does my experience.
I have warm white bulbs from Boatlamps in both my bicolour and tricolour and they work just fine. The greens are a little bluer than with an incandescent bulb, but still unmistakably green. Cut-off may be a little less sharp, but with the bicolour (Aquasignal S40), which has a flat reflector behind the bulb, it.s a marginal change at most. Perhaps a little more with the tricolour, but since the LEDs point outwards the columsn which aren't behind the join have much less effect.
I looked this up before, and the crossover angles are quite generous. Something like 6o, iirc. Wouldn't surprise me if this is to permit paraffin lamps.
Edit: And remember that the red must be visible to starboard and the green to port (on large ships by 1 - 3o) so that other ships can spot a head-on approach. https://assets.publishing.service.g...file/291901/00_-_msis_10_rev_4.0_draft_v2.pdf refers.
While this is true, I suspect that being bright and seen and alive to argue the point might be more important than not being seen (either due to a dim, flat battery or a dead bulb) and drowned ... better to be judged by 12 than carried by 6.
+1 for the Boatlamps LED bulbs...but you really should use the proper red/greens. The colour is great, they work really well.
One thing about going to an LED stern light is that they are very bright indeed...mine illuminates all of the sugar scoop-esque transom on my B32. Whilst it might make me arguably a bit easier to spot, or certainly add some scale to the boat, I do wonder if all the reflected light might make it harder to spot something coming up on me from astern.
Are people using Boatlamps LED replacements in their nav lights using the very expensive waterproof Led bulbs for bow and stern lights, or the much cheaper £4-£5 offerings?
- W
- W
I changed mine at the masthead, about 5 years ago, for a warm white Bay15d 18SMD which was (and still is I think) £9.99.
Seems to work fine in the Aqua Signal fitting.
