led lights issue
Your sketch wiring shows that you have basically series'd the two lights .... the dimness of the original light is based on the low energy flow allowed by the LED light ...
to make anything like this work - you'd need at least Double Pole / Dounble Throw switches to isolate each light from the other ..
No he hasn't! Where is the circuit with one or both switches OFF. Even with both ON they are still in Parallel.
Meant to add to the mix that when both switches on only the ceiling cabin light illuminates 🙈
Thats the missing bit of information that could solve the Murder🤣 Methinks you have dodgy switches 😵‍💫 Where did you buy them? They are two way switches but you have used L1 on both switches to feed the lights so they should be OK. Even if you had used the other (L2) terminal the switch should operate in one direction or tother!
P.S. Ignore the series theory.
Drawing skills (and wiring it seems) not my forte, but if you look at where the ? Is, I had initially tried sharing the negative on L1 of cabin light switch. This resulted in red led illuminating but cabin light was also dimly lit when it was switched off.
I have attached a test wire from batt neg to black wire of red led and works with no issue so guess I cannot share the neg of the cabin light? This is a bummer as was hoping to replicate this in all three cabins.
No scorching on the light switch as it is brand new.
No reason not to use a common negative, no matter where you connect it, it will still be common, it has to go back to the battery somewhere/somehow.
Run a negative wire to the negative terminals of all LED lights.
Run a positive to the common on both switches. Connect each L1 to either the cabin lights or the red light.
That's it.
You cannot/must not connect a negative to any terminal in either switch, it will just create a dead short.
Don't be fooled into thinking the black wire in the two core cable is negative, it may or may not be.
No, single pole, single throw switches are fine. He's using two way light switches, but if he sticks to using L1 on both switches it will work, when he wires them up properly ;)
I have tried two other switches and getting the same result…..beginning to wonder do I need red night time leds 😤
Where is the other end of the black wire connected ?
What is connected to the negative terminal of the red LED ?
I think the black wire is your issue. If the cabin lights work OK with the black wire disconnected, leave it disconnected for now, connect a new black wire between the negative of the cabin LEDs and the negative of the red LED.
The neg wire of the red led was connected to the L1 terminal sharing it with the neg of the cabin light.
When I remove this the cabin light work as it should, switching on and off normally. As soon as I reconnect the red led neg I am back to square one.
leds need very little current to fire up.
FWIW, I ihave two circuits selectable at the main control panel one for white, one for red. The red positive circuit is connected to the red leds. The white circuit positive is connected to the white leds. The returns from both go via a single local switch to negative.
Having experienced a traumatic delivery trip from Swanage to the Hook in night time, foggy conditions with the new owner on board who insisted on switching on the cabin lights every half hour or so, I like having a master control!
None of the neg wires should be attached to any terminal on the switches. You only switch the 12V.
Negative connections to each lamp or set of lamps are made outside the switch.
