Replacement Instruments - recommendations?
neil1967
28 Nov 2007
Tavira, Portugal
I am in the process of buying a new (to me) yacht, which has B&G Hornet 4 instruments dating from 1987. Neither the wind speed nor direction instruments work (normal or close hauled), the depth gauge reads erratically (depth disappears and is replaced by a series of horizontal moving bars every few seconds) and the log is over reading by around 2 kts (may be adjustable, but I normally expect to see under reading!). I believe that the time is right to replace the instruments with something more modern. I cannot afford like for like B&G replacement (around £5k) and will be using the yacht for liveaboard cruising, so I don't need anything too flash, but I would like a reliable set of instruments that are relatively easy to install, are networkable, and are not so proprietary that I could not add to the system at a later date. The yacht is also fitted with a Raymarine C70 plotter and Raymarine GPS which I would like to connect in (not currently connected to the Hornet 4!). Raymarine ST60+ would seem an obvious choice, but again they are not cheap. I would be grateful for any suggestions for alternatives.
Neil
sailorman
21 May 2003
Here or thertemp ashore
Neil
i have a Hornet 4 wind spd transducer for sale ;)
Shanty
20 Jan 2002
Scotland - Black Isle
A couple of years ago, having tired of continually repairing NASA instruments, I fitted Garmin.
I'm very impressed by them. They are networked using NMEA2000, so very easy to do, and easy to extend.
A vast improvement on the earlier version of NMEA. The displays are very clear and can display any of the data available on the network.
I added a Lowrance plotter. That was plug and play, with data from the Lowrance available on the network with no setting up required.
Slipperman
30 Sep 2009
Hampshire
I replaced all my old Navman instruments 2 years ago with TackTick, and they have been brilliant so far. In particular the wireless wind system means one less reason for going up the mast.
Jacana
12 Jun 2005
Derbyshire
This topic keeps re-appearing and it is ridiculous that the yachting community is so poorly served by what are fairy basic but unreliable instruments often at ludicrously high prices.
If someone were to produce a reliable and straightforward product range with less unnecessary bells and whistles and a price to match they would clean up the market.
Ex-SolentBoy
25 Nov 2006
Garmin instruments are reliable, straightforward, do the basics very well and are reasonably priced IMHO.
NMEA 2000 is undoubtedly the way to go. Los of flexibility and easy to install.
uxb
30 Sep 2008
Up high
Until the battery needs replacing...
That's why you fit the solar ones....
I'm in the process of fitting Tacktick to my new boat. Very easy to fit, simple to set up and the last set never gave any trouble.
With negligible power consumption. ( the sounder needs a 12 DC supply. )
SailorBill
21 Nov 2011
In a world of my own where you lot can't find me
So how do they work at night then? :rolleyes: ;)
richardbrennan
10 Dec 2008
If you decide to go for the ST60+option; I replaced a set of ST50s with ST60+ last year. I bought them as a bundle (wind,log,depth) from the Marinesuperstore at Port Solent which gives a reasonable saving over buying them individually.
sailorman
21 May 2003
i relaced all my B+G stuff 12 yrs ago with ST60s + A/H 6000+. sooper kit but it was made in England :cool:
Goldie
29 Sep 2001
Nr Falmouth, Cornwall.
Sailing instruments were reviewed in Nov 11 YM, P76, along with a couple of paragraphs about networking. Not all ranges were tested - the most obvious omission being the ST60+ range - but the best mid-range buy was voted the Garmin GMI10.
NMEA2000 looks very easy to install/expand (on the face of it, not first hand experience!)
SailorBill
21 Nov 2011
A review of sailing instruments that doesn't include one of the most popular brands :rolleyes: Not much point in taking much heed of the results then!
sailorman
21 May 2003
i think Garmin will be market leaders in the future
