MattS
I have installed a new Isotherm kit into my fridge, and want to avoid using the rather delicate-looking thermostat control as the primary method of turning the fridge on and off.
In order to avoid as much voltage drop as possible, I am taking a direct route from the battery isolator switch to the fridge via a fuse. The main wiring behind my DC electrics panel is not up to the job of feeding the fridge directly.
I'd quite like an easy-to-reach on/off switch for the fridge on my electrics panel, so I plan to use a solid-state relay to switch the main fridge supply on and off via a simple push button on the electrics panel.
Can anyone tell me firstly if there's a reason that this is an awful idea?
Secondly, I've found this solid state relay, which has a load current rated at 10A. The fridge shouldn't be drawing more than 5A when it's working hardest, according to the specs. Would this component be appropriate?
https://www.amazon.co.uk/gp/product/B01M075K7L
Are there any alternative 'known good' relays for use in 12V marine environment which would be better for this job?
Thank you!
Matt
Thank you!
Matt
