Little Dorrit
I'm not an electrician but we're dealing with 12 Volts and whatever the set up you'll need a supply to the refrigerator so upgrading the cabling etc would be quite easy and a good quality switch rated for 10 amps should be sufficient.Thanks - I'm just trying to achieve the same outcome as you have with your setup, but without having to significantly extend the main 12V supply cabling to route it via a switch (which would increase the voltage drop).
To locate a switch on my electrics panel, wired directly in line with the supply, I'd have to add a good 3m to my 12v supply circuit..
So my idea to use a relay was to have a switch located somewhere convenient, but without a significant interruption to the supply circuit![]()
