taikohax
Firstly - apologies if i've got this in the wrong section.
I own a Beneteau Oceanis 45 (yes I know, boo hiss etc
) and the rear pushpit (pullpit? sorry, not sure the correct name) which holds the outboard is only rated to approx 25kg.
The outboard i'm going to put there is approx 40kg.
Knowing that Beneteau "build to a price point" that leaves me with the following challenges to overcome :
After waiting (and chasing) for a quote from my local workshops for well over a month* i've decided to start working out how to do it myself (or at least mitigate some of the cost).
* side note - i'm new to boating, have only had the boat for 4-5 months, but i've been baffled at how little the marine industry seems to want to make money or engage with customers (and when it does it adds a 200% premium on top) - everything's been "eventually get around to it" or "oh, you mean you ACTUALLY want a quote and for us to DO the work?". Possibly (likely!) a naive comment but I can see why so many people go "bugger it, i'll do it myself". Maybe i've just been unlucky (that being said, the guy who fitted our heater was solid gold so i'm likely just being grumpy).
Anyhow. I'm writing this to hopefully pick some brains to see if you think the approach i'm proposing below is sensible (and if you have any advice you can add) - namely :
I'm reasonably 'handy' however this is my first boat and i'm conscious there's a wealth of experience I lack and i'd rather avoid stupid mistakes since my knowledge of the boat 'structure/composition' is limited. At the same time, I have limited free time (still working heavy hours unfortunately) so where I can buy 'off the shelf' at a reasonable price i'd certainly like to do so - since i'd rather be using the boat where I can!
I've attached some pics below (and added a link as the pictures didn't appear in preview) to give context - all advice and experience welcome
https://photos.app.goo.gl/h0wR7JIEqXy4rj632
- Strengthening the rail base for the downward force presented by the additional weight against the deck
- Strengthening the underside of the deck (where there are petit washers) for any force going 'upwards'
- Making it as easy as possible to lift the engine too/from its mounting point without falling in the water or sacrifing it to the sea.
- Unscrew the rails, slide a slightly wider stainless steel 'washer' in-between the existing pushpit and the deck to spread the load downwards (is there a way of mitigating 'cracks?' is there a durable rubber or plastic washer you'd recommend I put in-between?
- underneath the deck, add a wood (not sure if I need a specific type - open to recommendations) board to spread the load upwards and ideally a wider SS washer.
- Mount an outboard hoist/davit (similar to the ones F4 and others sell) - ideally also bolted to the rail to give it some extra stability for lateral movements
