Recutting the binnacle for instruments
jimi
19 Dec 2001
St Neots
At the moment I've go wind, auto & tridata on the binnacle with the Radar on an instrument pod above. I hate the instrument pod and wish to get rid of it .. but I want the radar display visible from the helm. This will invove recutting the binnacle. Any ideas .. think BoatMike? did something similar last year and I'd be interested in his and similar experiences.
tcm
11 Jan 2002
Caribbean at the moment
if you can find the manufacturer twd be a good idea to buy a new blank to reposition everything.
Dunno why you hate it tho. It's fine. wot dya think is wrong with it? okay, so it looks like an adapted midget's bath but otherwise quite ok, and i reckon you are just feeling you oughta do some boatfixing to keep up with everyone else efforts over winter when you've done sod all other than upgrade to a 2005 packet of butter.
jimi
19 Dec 2001
St Neots
erm .. I added an SSB receiver and aerial, cleaned the boat, refixed a leaking hatch and wiped down the stove!
DOn't know why I don't like it, its fuctional etc etc but maybe its just too much in the face..
FullCircle
19 Nov 2003
Jimi,
I have fitted all that and an ST4000 head to my binnacle, but Jeanneau redesigned the thing with a deeper back bowl, to accomodate the 6.5 inches clearance behind the fascia for the radar and plugs. It was redesigned foir the 2005 model year. I also have room in the back for the Navbus junction box, the NMEA junction box, the Seatalk to NMEA junction box, and 6 way fused power supply distribution box.
I needed these extra boxes for the amount of NMEA interlinks, and to provide a clean strong NMEA signal back to the chart table where I have a Navman 3100 Repeater.
Wiring up the pedastal is a problem, it means that Radar cables have to be cut and refitted with plugs after threading up the conduits, which is a sod for servicing. Assemble and connect as much as you can to the 'lid' so that you can remove the whole shooting match with very little disconnection. Leave a reasonable length of wiring to allow working on the underside when needed.
I think yours has a Goiot pedastal same as the Jens, so you might want to enquire at the Jeanneau dealers (Clarke & Carter round here, Westway down your end) and see if it is a possible retrofit. Also, the sages will tell you that you have clipped the compass safe distance under the minimum recommended, but I am going to suck it and see with a decent swing, equipment on/off. Can always return to the previous condition if its too bad.
/forums/images/graemlins/blush.gif
Jim
PM me if you want photos of the setup.
ParaHandy
18 Nov 2001
is there enough room to remove all three st60 instruments and fit the radar display in their place ... or something similar ... and then, remove binnacle altogether?
larger crew members will welcome the removal of such a fragile handhold ...
BlueChip
24 Aug 2004
Bucks/Plymouth
Get a sheet of white perspex or similar material from a sign maker and overlay it on the existing binnacle surface. If you make a cardboard template, the sign maker will easily cut the perspex for you, round the corners and bevel the edges and it will look fine. Cost should be just a few pounds if not free if you ask nicely
BlueSkyNick
29 Apr 2003
Near a marina, sailing club and pub
".....you might want to enquire at the Jeanneau dealers (Clarke & Carter round here, Westway down your end."
Actually its SeaVentures who have taken up residence in Hythe (where we and Jimi are moored) this year, preparing newly imported boats for delivery to their owners. Already quite a few tales to be told - some other time, maybe. /forums/images/graemlins/smile.gif
boatmike
30 Jun 2002
Solent
I only read as far as "At the moment I've got wind" first time and thought..."so whats new Jimi? Then I read the rest!
Yes mate it was me, but not on a binnacle. My wheel is bulkhead mounted on a sodding great big column with an instrument facia on top which is about 2 ft wide by 18 inches deep. I needed to reposition all my instruments so I used a bit of white UPVC board left over from cladding my house, cut all the holes in that with a bit of reinforcement underneath and bolted that down to hide all the old 'oles. Looks very good and allows easy access to the wiring behind by lifting the whole panel. Only problem is UPVC is a bit soft and can scratch easily but I dont find that a problem as its not exactly a work surface. If you want something harder you could face up with laminate I guess.
Gunfleet
1 Jan 2002
Orwell
I think Aladdin\'s cave can help
They are going to start stocking cuban heeled seaboots this season. If you wear those with lifts and stand on a small orange box you should just about be able to see over your binnacle.
Gunfleet
1 Jan 2002
Orwell
Sayonara
Listen, Lochinvar, you haven't laid off me since I fixed you up with that drunk bird in Japan. His whole blinking boat is fragile!
Rob_Webb
20 May 2002
Auckland
Bulkhead
My helmpod has 3 small units (multi/wind/autohelm). And I installed my plotter screen in the cockpit bulkhead. It's a decent-sized colour screen so it's visible to the helmsman and crew in the cockpit and it's also out of the worst weather - although it's supposed to be waterproof. Why not mount your radar screen in the same place?
