Refueler
See Sea Change reference to Rod Collins, I think he proves that long life, of LFP batteries, is quite possible. Human life is a bit more frail. Rod used to be Mainsail on CF
Here we go - I've done the hard work for you (but I misled - its not 15th Anniversary its 15th Birthday - apologies.)
Jonathan
The large batterys used are of low C rate .... the reason you can long life and reasonably high discharge rates is because of the Capacity x C rate equation. As I posted before ... Pauls 140A rate from his is most likely based on having high capacity ....
That Lithium Leisure battery linked to by another earlier ... once my meds had 'backed off' ... I looked again .... 100 A/Hr .... max discharge rate 100A ... means its a 1C system .... so if anyone pulled anything but short burst 140A out of that too often ... it will suffer and have reduced life. Pull 280A out of it and it definitely will go see its maker in short time ! The c loser you get to max discharge rate and if done often repeatedly - life of the battery will suffer.
This and previous have said about C rates x Capacity .... that's a factor that must be taken into account ... not just capacity alone. Do not forget also that if you have higher C discharge rate than what's generally in this form - the C charge rate does not necessarily follow ... at low C rate ... the C(D) rate and C(C) can be same ...
Its interesting as the more you look at these LiFePO4 .... they purposely keep the C rates low ... and rely on capacity to deliver the goods ...
Just for the record ... I do use LiFePO4 along with LiPo ... LiIon .... LiFe .... depending on the use and setup. In many sizes from tiny up to 20 A/hr ...... not your sizes I agree .... but the chemistry is still there ..... plus various have their Smart BMS etc ....
