Sea Change
You don't need to live somewhere sunny for lithium to make sense. In some ways the case is even more compelling if you do most of your charging from your engine or a generator, because you don't have to spend hours getting your batteries up to float. You can cut your generator running time significantly by changing to lithium.
Lithium doesn't make sense for everybody. If you've got a small boat and are happy to replace a couple of lead acids every five years, then the one off ~£300 needed to upgrade your system to be lithium compatible is hard to justify. But for many people it's now obvious that lithium is well worth that investment.
