Blue Sunray
Do you check your life jackets at all? Same thing really, but in a different way. All about mitigating the risk.Would the ones that do a radio check every time they go on their boat also do a life jacket test?
Ooh ... I dont go out when its that windy ... or is that boat speed over the ground
Yes I do, but around once a year rather than every time I go out on the boatDo you check your life jackets at all
By which I assume you mean on the local calling channel, where available. This is 67 in the Solent.I definitely understand the need for Radio checks but agree with other comments that it should be done on Channel 65.
AbsolutelyBy which I assume you mean on the local calling channel, where available. This is 67 in the Solent.
CH65 is the NCI channel. CH67 is the usual CG working channel.By which I assume you mean on the local calling channel, where available. This is 67 in the Solent.
The above statement is wrong and potentially risky. 16 is the calling (and distress) channel, in the Solent and everywhere. 67 is a working channel.By which I assume you mean on the local calling channel, where available. This is 67 in the Solent.
Twenty something years ago (swing the lamp) I was delivering a boat up the Adriatic to iirc Pula. We were overtaken by a fast US Warship and heard the best thing ever on VHF.Yes, 'Minky minky' is a common one; also I've often heard something like, ' Diddikoy diddikoy', it can't be the same as the word used here for gypsies presumably, so it must mean something unforgiveable in Filipino..I wish the Solent was as colourful..
Nope, 67 is the calling channel for routine traffic in the Solent, as Pete just confirmed. 16 is also available for calling, of course.The above statement is wrong and potentially risky. 16 is the calling (and distress) channel, in the Solent and everywhere. 67 is a working channel.
Edit, as others have already said ^^
Yes, if you know the channel you can call on it, eg VTS, Port Control etc. I'm going to look up the latest Solent CG channels.67 is a working channel, but for many years Solent Coastguard promoted a modified local procedure where routine traffic from leisure vessels was to be made directly on that working channel rather than via ch16. I thought they had changed that, but either they didn’t or they’ve changed it back.
There’s nothing unusual about calling direct on a working channel when the published procedures say so. Ships don’t call VTS on 16 first.
Who mentioned 'routine traffic'? Is this still about radio checks?Nope, 67 is the calling channel for routine traffic in the Solent, as Pete just confirmed. 16 is also available for calling, of course.
