Radar Reflector
DIW
22 Sep 2002
Shropshire & Deganwy
Radar Scanner is fixed on the Radar Arch , if a Radar Reflector is fixed on the same arch will it cause interference on the radar ? or is it better to fit the reflector on the coach roof away from the Scanner.
Ian
Steve Clayton
22 May 2003
Benitachell - Spain
www.aloeland.co.uk
It's a tricky one to say with total accuracy. Yes it's too close to be received as a target as the radar will be in transmit (ie not receive) mode. If the pulse is prevented by travelling further then you're likely to have a blind spot behind the reflector - a bit like an eclipse.
The reflector is also likely to bounce the signal - so watch your ovaries/gonads!!
