LittleSister
There's no requirement to have a reflector, but it is undoubtedly safer to have one.
I disagree. There is severe doubt about the effectiveness of most of the passive radar reflectors of the sizes and types used on small to medium sized boats. Having one may or may not increase one's visibility to other vessels using radar, and may give the boat owner false confidence they are visible to other shipping.
I am not for a moment suggesting not having one, but cautioning against false expectations of how much, if any, additional radar visibility is actually being achieved.
The OP has a 25' motorboat.
The boat itself, and it's contents (especially e.g. engines), will reflect radar, but not necessarily strongly or at all consistently.
It is not actually impossible, but decidedly impractical to carry an effective-sized conventional passive radar-reflector on a boat this size or smaller. Size is extremely important in the amount of refection that can possibly be achieved, and the design (and correct orientation mounting) of the reflector is very important in determining how much of such potential reflection is actually achieved from different angles both from the heading of the boat and vertically from the horizontal as the boat is heeled or rolling.
In an attempt to overcome the size challenge, many sailing boats have a patent-array-in-a-drum type reflector mounted on the front of the mast, but these apparently suffer from being screened from a significant sector aftwards by the mast itself.
An active radar reflector apparently overcomes most of a passive radar's shortcomings, but at a cost not all can afford or tolerate, and is of course dependent on the continuous availability of a power supply (though rarely a problem on modern equipped boats). The model depicted in post #7 operates only on one of the two radar bands that ships might be using. Two band types are even more expensive. I've never been clear how much of a disadvantage the lack of the other band is. (Neither do I know how consistent (or not) the re-broadcast signal is around the 360 degrees horizon, or at different vertical angles fro the horizon.)
How visible you are, even with the best kit, will very much depend on the weather, how rough it is, the quality (or otherwise) of the radar gear in use by other vessels, and the settings the operators have applied to their gear.
Of course, in a big swell your boat and radar reflector of either type may well be screened from radar view a significant amount of the time, and hence not be picked up (see srm's post 20 above.).
One can only do what one can to increase the likelihood of radar visibility, depending on boat size/type, depth of pockets, etc. and hope for the best. Don't bank on always being seen, though!
