Rappey
In this video they try different methods of filling a hole.
Instead of selftappers I carry a fist of tecscrews usually used for roofing.
A battery drill would be essential...you often get a head with the packs of screws...I presume you have to have a battery drill or impact driver to use these? Like the idea though.
The method with the ply followed up by a ply patch on the inside all screwed in place with tecscrews would seem like a good option...maybe with a lump of epoxy or other self curing material in between.In this video they try different methods of filling a hole.
When I did the Atlantic the wife bought me an axe to be used to access a hole behind all the nice woodwork. If the water was pouring in I would use it.Inaccessible areas of the inside of the hull make me uneasy. Most yachts have them, but there is a wide range, from a sparsely fitted-out old Colchester smack, to the floating yuppie apartment type of a gin-palace.
Might I suggest that the forward parts of the hull are more likely to hit a floating treetrunk, or an awash shipping container, therefore they should be a higher priority for access than the ass end?
I like the sound of those screws.
When the rigging is on the deck, a small handheld set of cutters to remove the split pins then knock the cotter pins through. I have done this it worked for me.Good thinking. I've acquired an AldiLidl battery drill-cum-several-other-functions specifically for the boat. One feature is an angle grinder... with 1mm stainless cutting discs, I reckon it would make short work of cutting away a tangle of s/s shrouds.
Yes, and a second battery, charged, makes better sense to me than an expensive set of wire cutters that aren't quite up to the job.
Inaccessible areas of the inside of the hull make me uneasy...
... an angle grinder... with 1mm stainless cutting discs, I reckon it would make short work of cutting away a tangle of s/s shrouds and a second battery, charged, makes better sense to me than an expensive set of wire cutters that aren't quite up to the job.
I suspect that in the conditions you're likely to lose the rig in, you're unlikely whilst offshore to easily wander around with a dremel/mini-grinder cutting them free
I am in the process of assembling the various tools, lotions and potions required to keep afloat and moving whilst underway to Baltimore and hopefully the Azores.
I do have a question.
Should my hull get holed below the water line, say I dumped into something at sea, what would be the best stuff to use to fix the hole and make the hull water tight again?
I am not talking about a very large hole, which will probably be pretty catastrophic, but a smallish puncture hole from say a log or floating piece of metal.
I have wooden plugs to plug the hole as well as floatation cushions which I can use to quickly place over the whole and then a broom handle broken to the right length to keep it in place. This should hopefully reduce the rate of water coming in to give me time to affect a repair.
But, does anyone know what I should carry to fill such a below the water line hole whilst at sea and working from within the hull? I would want to avoid having to dive overboard to do the fix if I can.
