Anchorite
Have a std Vetus shaft, 30mm, with a 16" prop?. Have bought a secondhand
bigger Volvo prop, same taper....but the keyway is 10mm as against 8mm for
the Vetus. Two solutions: shape a piece of 2mm s/s to take up the play, or
drill through the Volvo hub (there's about 12 mm available on forward end) and
fit a shear pin.
Has anyone done something like this and of so what shear pin recommended?
Motor (inboard) is about 50 cv max, 2500 rpm max., prop 1250, behind semi-
long keel.
fit a shear pin.
long keel.
