rustybarge
Assuming that both the monohull and the cat have efficiently designed hulls and the same overall weight, I'd expect the cat to burn a bit less fuel.
But that has not so much to see with the hull speed point you previously raised.
In fact, even if it's true that the (max) hull speed of a 34' cat can be higher than the one of a monohull, I don't think it's correct to compare that with the hull speed of a 68' monohull.
Length remains more relevant than beam, AOTBE.
I made the mistake of asking a question like that on the boat design forum, after being bombarded with prismatic coefficents and other esoteric formula, I decided 'rule of thumb' was the best policy: 'If it's fat and heavy it'll probably use more fuel'
