perkins twin 225s
timv
9 Jan 2014
ludlow
Would these engines be underpowered in a 37ft colvic sunset ,and does anyone have any experience of them good or bad ? Similarly with the Clovis itself ?Many thanks- Tim
Latestarter1
6 Feb 2008
Somerset
What does old Colvic Sunquest weigh?
Perkins Sabre 225 has a bit of a blunt edge, if you use the Bosch VE spec sheet maximum output can only be 185/190 which has led to lots of grumpy owners over the years.
timv
9 Jan 2014
ludlow
perkins 225
Sorry I meant a colvic suncruiser which is a bit smaller I believe but still sounds from what you say latestarter it will still be a bit disappointing on the sea, unless anyone has any other views ? Thanks LS.
Seastoke
20 Sep 2011
we have 225 in our colvic she gets 20 21 knots full poke we tend to plane at 17 is as sweet as a nut but would like a touch more as would all of us
Latestarter1
6 Feb 2008
Somerset
Anemic power output was problem for owners who re-powered vessels which had on the face of it existing engines of nominally lower power. In one specific case owner who had a pair of tired old Ford Dorset 212's re-powered with PS 225's and lost almost 3 knots. Met with the owner who had commissioned the re-power and I checked the whole installation, it was faultless. Biggest beef by the owner was the WAY that PS 225 delivered power, his geriatric old Ford Sabre Dorsets smoked like crazy on start up, and oil carryover filled the puke bottles after just a few trips out, but what owner could not get his head around was difference sheer get up and go, comment was that he could roll a fag after putting the hammer down whilst engine got its act together, the previous old ladies had real urge by comparison. (Are you listening Omega).
Later Ford Sabre Dover 225's would simply blow the doors off their successor the Perkins Sabre 225's.
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
LS , one if your past comments a out the crank in these motors , resembles a bent paperclip always makes me chuckle .
omega2
17 Oct 2002
Essex Bradwell UK
Loud and clear, getting one ready for the warm weather.
Latestarter1
6 Feb 2008
Somerset
Rods are just as skinny, recently looked at PS 300 which had failed a charge air cooler in a big way, causing it to hydraulic bending the rods so badly that two would not come up the bore, dealer ended up gas axing rods to get them out. Was also surprised that later Perkins Sabre has no locating tangs on bearing shell.
