graham
every year or two I lift the boat up and lower the lifting keel to wire brush the steel part of the lifting keel and paint it with metal primer.
The bottom part of the keel is a cast iron lump of ballast which remains outside the boat This is attatched to the end of the plate which is an inch thick mild steel plate which goes up into the case when raised.
Can anyone recommend a good paint that can stand the abrasion of being winched in and out of the keel case?
Hopefully then it wont need doing as often .
