richardh10
When you have cleaned off the oxalic acid that you have used on the deck, does the residue that is washed into the sea cause any damage?
Why are you using oxalic acid on your decks - Boracol or Patio Magic are better at removing algae. Rust stains would be an excuse, I suppose.When you have cleaned off the oxalic acid that you have used on the deck, does the residue that is washed into the sea cause any damage?
[/QUOTE
Oxalic acid takes dark patches out of wood, and removes rust stains. Pretty useful product and is environmentally friendly compared to nasty biocides like you suggest
I don’t know the answer but it is an organic compound found in citrus, spinach and others. It’s not a synthetic long tailed polymer. But clearly the stuff we buy is high concentrated.
Causes kidney damage.....enters through bare skin.....A google search shows a statement from the US National Organics Board stating:
“Since oxalic acid is naturally occurring in the environment as well as in honey, and its use has little to no negative environmental impact, its use is not considered damaging to the ecosystem”
from chatgpt, often a better place to ask than in here ( or in addition to) ...
"how harmful is oxalic acid if wash into the sea
Oxalic acid is a naturally occurring organic compound found in many plants and vegetables. In small amounts, it is not harmful to humans or the environment. However, if a significant amount of oxalic acid is washed into the sea, it can be harmful to marine life.
Oxalic acid is a chelating agent, which means it binds to minerals and metals in the water. This can lead to a reduction in the availability of essential nutrients for marine organisms, which can affect their growth and survival.
In addition, high concentrations of oxalic acid can lower the pH of seawater, which can be harmful to marine organisms that are sensitive to changes in pH. This can disrupt the balance of marine ecosystems and lead to the decline of certain species.
Overall, while small amounts of oxalic acid are not likely to cause significant harm to the environment, large amounts can have negative impacts on marine life and should be avoided if possible."
far more than the other replies so farDoes this really explain anything?
A. Slightly different function, as you noted.Why are you using oxalic acid on your decks - Boracol or Patio Magic are better at removing algae. Rust stains would be an excuse, I suppose.
If you haven't got tannin stains would you still use oxalic acid?
https://forums.whirlpool.net.au/archive/2774469
Just don't be profligate with the oxalic, spot use seems a good option.
Very timely thread for me. I've never used oxalic acid for cleaning but my deck needs a thorough cleaning and has some rust stains. If I buy it in powder form how much should I put in a bucket of water and what precautions do I need to take to prevent injury to myself.
