simonfraser
It's a small hand pump with gauge and a hose that screws into the drain hole . I borrowed it from a friend - sorry no photo.
Not sure where to buy one ..... gearcase pressure tester .
What pressure do you test it at ?
Thanks for the response so far, some helpful stuff. My recollection was that a re-build should be done around 1000hrs and I was aware of the 'fix' for worn shafts with welding or chroming. Can you advise what sort of money that is Pete?
£6k sounds a bit steep even at VP prices BuceK?
Easier if you wouldn't mind please see the manual for the drive for details of the correct procedure - which is available free onlineWhat pressure do you test it at ?
I dunno, I know a fella with a Prestige who got a repair bill for circa £20k for his shaft drive gearboxes. May be less common, but not totally unknown.
Greg, I don't have the exact cost as it was bundled in with other wok but I think it was a £100-£150 a side so a huge saving over a new shaft.
Thanks Pete. That sounds very reasonable and is a vast difference from the £000’s that replacement shafts seems to attract going by reports on here. Any idea how good the repair i.e. how long is it estimated to last for?
Has anyone had both and can do the real maths based on fast cruising mileage?
how big was the boat 80 feet plus? - sounds like he was well and truly shafted (no pun intended)
Better than doing nothing.Just pressure testing is pointless. All you are checking is that no oil can leak out.
I would not agree with the fuel economy benefit. We travel in our f33 on outdrive with a f36 on shafts. The f36 does use more fuel but perhaps 20% more. I think that makes shaft drive pretty much equal on fuel use.I find it very hard to justify outdrives, I envy the high speed, great handling, fuel efficiency.
for: super efficient - save on diesel, fast boats, sporty handling
against: religious servicing for reliability, expensive oils and parts every two years, fishing line damage, plus the real risk of something serious ruining your summer/bank balance
shaft drive
against: 50% more fuel use when going fast.
for: about as complicated as a horseshoe, sod all gearbox servicing, £60 cutlass bearing every 4 - 8 years, cheap oil every 5 years or so, a £6 anode yearly
if you trash a prop the cost is about the same either way, a new prop shaft for a 50 footer is £900, a recon gearbox is @ £2500 for a 40 footer.
How many threads are there on knackered outdrives? How many threads on stuffed shaft drive gearboxes? (about 3)
I wonder at what annual mileage (note not hours) is it worth having out-drives? Has anyone had both and can do the real maths based on fast cruising mileage?
I have concluded that nothing on boats is cheap , doesn't matter if it's shaft drive,outdrive or sail. Maybe outboards are the exception to that rule?
I have heard of gearbox issues on shaft drive boats that have been expensive to fix.
I find this thread rather depressing
Dennis, outdrives have lots of advantages (fuel economy, ability to flip in an impact, availability of spares (and props), ease of removal for repair, etc). And in any case, if you want a sports cruiser the chances are that you're stuck with outdrives.
As for the high repair costs, I think some of the above people have been unlucky. As long as you don't scrimp on maintenance the likelihood of a very expensive repair bill is relatively low.
Anyhow, you should be thankful you've only got one!
I got 2 one on each boat
When I am on the Norfolk broads for example there are hundreds of boats on outdrives that sit on the water and don't come out that often. I cannot believe that all these people are either having the level of servicing done or indeed the massive bills you suggest. I might be incorrect of course who knows
Dennis
