Origin of I, J, P, E rig measurements?
ds797
16 Jul 2003
So we have the "standard" rig measurements of I, J, P and E.... but I am curious as to where they originated from... I guess I mean what do they stand for? None of them seem to be "initials" of the name of a dimension! Idle curiosity thats all!
Roberto
20 Jul 2001
Lorient/Paris
sybrancaleone.blogspot.com
Is there an initial for roach?
The first time I saw those initials was in the IOR measuring rules, there were letters or groups of letters for a lot of elements, for rig, sails, hull, propeller etc. On the mainsail they measured how much each batten was protruding from a line head-to-clew, there was a limit beyond which penalties were applied.
Or for example sail area was measured using -among others- JC, JC was a "corrected J": they measured J (base mast to forestay) and the Spinnaker Pole length, the bigger was taken as JC, which of course led to having all spinnaker poles maximum length equal to J. Also, there was a penalty for genoas having an LPG (perpendicular from clew to forestay) grater than 1.5 J, which led to genoa #1 being all 150%, and so on.
There were letters for canoe body draft, freeboard, beam etc taken at various fore and aft sections of the hull, and at various spacing from the centerline: as the draft which "counted" most in the rule for determining displacement was one at some distance from the centerline, and not the one at the centerline, all hulls had a flat underbody in their central area sections.
Also, hull length was determined comparing two sections fore, and two sections aft, in particular their girth: the more the girth difference, the more the rule "thought" the boat was pointy and the less length was considered: that created those horrid "bumps" in the aft section at the rudder, the one aft section girth was reduced, the rule was attributing a lower dynamic length, hopefully the worst water flow at the bump was less important than the gain in "measured" length.
Plomong
7 Feb 2006
Bilbo, Spain (Basque Country, actually)
A few months ago I was looking for information on the IOR measuring rule, and the elements that fed into the final calculation, with little success. Do you know where I might find a complete list of all elements included in the calculation, including corrections applied, etc ??
Plomong
anoccasionalyachtsman
15 Jun 2015
Plomong
I'd imagine that the Rating Office would have the ability to print a copy. This thread has reminded me of how annoyed I am that I chucked a copy of the rule away about three house moves ago.
Roberto
20 Jul 2001
Lorient/Paris
Plomong
I do not know if there is anything available online. I have all the paper documents in my former home, unfortunately not here where I live. The booklet looked similar to a pilot book with corrections :D : every year new additions and modifications were made, one had to cut and glue the strips of paper over the relevant pages of the rule booklet.
Plomong
7 Feb 2006
A document such as you describe, for a known version (e.g. V23.6 30-June-1988 or whatever) would suffice. Problem is how to locate such doc !!!
It doesn't need to be the most recent version, just that of a known version and/or date.
Plomong
Roberto
20 Jul 2001
Lorient/Paris
Plomong
I have it in Italy, the problem with all this Covid mess is I might get it no sooner than Christmas holidays period, at best and if we will be allowed to move.
ps I used those rules to design a One Tonner when the rules changed and put one tonners rating limit at 30.5', we even came 2nd place in a local yacht design contest for such boat :)
Plomong
7 Feb 2006
There is no hurry -- I'm retired from the rat-race of project milestones (or should that be millstones) some time now, so take tasks one step at a time.
Way beyond anything I could attempt. I once toyed with the idea of assembling a kit boat (Hunter 32 type), but the RCD and reality, timewise, stood in the way.
