Orca attack
Daydream believer
6 Oct 2012
Southminster, essex
I would imagine getting in position on the boat, where advice is to stay out of view, then aim the spray down wind, at an Orca within the time it surfaces is difficult. One does not know where it will surface or what side of the boat.. will it. Already have a chunk of rudder in its jaws. If so would it be wise to wind it up further?
Apart from that the water wil immediately wash off any spray. One should realise that the animal might be doing 10knots through the sea at the time & so the result might be irritating at the most.
perhaps the spray has been tried & rejected or put up for further investigation. No reasonable idea should get the cold shoulder.
Laser310
15 Sep 2014
the spray is oil based and does not easily wash off in water - think of eating a particularly hot vindaloo, and trying to ease the pain by drinking water... It doesn't work quickly.
it's certainly possible that the orca might just get more aggressive - but that is not the experience with bears. They mostly cease the attack because of the extreme pain. Again: it is considered more effective at stopping a bear attack than a bullet, because the bears are huge, and the bullet isn't that painful, initially at least.
certainly a moving boat would present difficulties.
on the other hand, you are not going to out run them..., so why not stop if they are biting you rudder, and try to give them a spray with this stuff?
it's possible that just a small amount in a blow hole or eye would stop the attack
in the videos they often surface near the boat
All I am saying is: in the waters off spain, we have a problem with large mammals causing trouble - even danger - to humans. It turns out that we also have a product - designed by wildlife biologists - to deter large mammals without causing permanent injury. This product has been very successful on the mammals for which it was designed.
Why not try it?
greeny
15 Jun 2004
Portugal
Why not try it?
Because you will only have the one chance to scare them away (if you're lucky and see them in time). If you use the spray and it doesn't work, your rudder may well be damaged before you can use something else. At the moment my money is on firecrackers, the only thing I've personally seen work.
Daydream believer
6 Oct 2012
Southminster, essex
My friends have taken diver recall signals. They have a fuse & are lowered into the water to a depth set by the string they are suspended on. The bang is meant to recall divers but close to an Orca would be better controlled than a randomly dropped firecracker.
they tried one on the boat & got a bit of a shock so it seems
rogerthebodger
3 Nov 2001
When I was SCUBA diving our dive master has a device attached to his dive cylinder that made a noise from the compressed aut when a valve was pressed
I wonder if this would work to ward if orcas
Zing
7 Feb 2014
Orcas use echolocation. It wouldn’t take much rocket science to make a device to work at the frequencies they are sensitive to and to make the volume and pattern so that they find it unpleasant and so go and make baby orcas instead. There’s surely a business opportunity in this for someone with some free time.
26 Dec 2001
Saou
There are already acoustic diver recall systems that work with a hydrophone, in the region of £5K so might be a tad expensive for the traditional cruiser.
Zing
7 Feb 2014
That would be, but most boats have echolocation devices already fitted that cost a tenth of that, so it’s not hard to imagine an anti-orca device could be made cheaply enough, all the more so as they will need no display screen or receive circuits.
Laser310
15 Sep 2014
that actually sounds like a lot of work...
and good luck getting any whale researchers to cooperate.
and to (legally) work with wild whales to test it would be nearly impossible.
supposedly, the US navy has worked on this - not with total success though.
If firecrackers work, and they can be obtained, that is probably the simplest way to go.
John_Silver
19 Mar 2004
St Mary's Island
allatseawithstargazer.blogspot.com
Such a device has been developed (by a company which has successfully employed a similar approach, to deter seals from predating on fish farms) according to this PBO news item . Be interesting to see how the trials off Galicia go.....
Thresher
19 Aug 2002
Tollesbury
it says near gibraltar
do we have a more precise location?
There is a report from insider.com that says the boat sank on the 31st of October at the entrance to Tanger-Med, a Moroccan port. That's at about the narrowest point in the straits of Gibraltar.
Strangely, it has not yet been reported either on orcas.pt or in the app Orcinus.
Laser310
15 Sep 2014
i found this position
the date is oct 31 61:36 UTC
kingsebi
6 Nov 2020
I read that no full keel yacht with the rudder attached to the keel got targeted by the orcas until now. Only free standing rudders. Can anybody confirm this?
