D
Deleted User YDKXO
Great news Bart, just in time for the season
Has the "new" engine been dyno-ed or is it a case of fingers crossed that it develops the correct power?
...........if someone is interested I can post some more pics from during the project, etc..
I'll update this thread when new info comes up
next week they will nevertheless replace the injectors and vibrationwheel on the old engine,
and try to find the cause of the small water consumption on that engine.
....He told me that the it's not unusual for MAN engines to self-adjust to the right level by "spitting" (so to speak) a bit of liquid when, after being topped up, the engines are used for a while at operating temp.
And also confirmed me that sometimes he found such level - for reasons he couldn't explain - to be somewhat different, also between two identical engines installed in the same boat, position, etc.
So, if you don't experience any further level reduction after an initial leak (starting from the topped-up level), you could try to leave it as it is, without insisting in topping it up.
But of course, if it continues to go down, I reckon that it's appropriate to find the leak and fix it!![]()
in your boots I'd rather replace plain water (if as I recall that's what you had in the cooling system) with the appropriate cooling fluid.
In the “new “ engine ofcause there is the correct cooling liquid,
In the old engine he adviced just to keep the liquid in there
As we will probably give that engine a similar overhaul after the season (less massive and less expensive), so that both engines have the same “condition”
At that moment he will clean and rinse all parts of that engine, and after assembling put the correct fluid.
He advised not to waste money on cooling liquid until then
Actually, B said that a level, not a temp alarm went off on BA. And that the temp is instead stable, in fact.I never experienced an over temp alarm like Bart did though.
Ah OK missed thatActually, B said that a level, not a temp alarm went off on BA. And that the temp is instead stable, in fact.
I'd definitely be more concerned by a temp alarm vs. a level alarm - provided of course that the cooling circuit is full, even if not as full as (in theory) it should be.
In my case, the coolant was being ejected out of the overflow pipes from the header tanks.
on that engine I could fill each time approx 7l to 10l of cooling water untill completely full.
on the other (normal) engine I could top up about 2 to 5l (don't remember exactly as I fill it with a hose)
I sort of got adrenaline rush just from reading this... :/ Hang in there...!
