Pinnacle
you know E well enough that she's not much interested in "expensive" small sparly things![]()
You are indeed a lucky man......
Best wishes to you and E from S and I.
Indeed. If I ask my SWMBO so much as to pull a fender in, it costs me a diamond ringYou are indeed a lucky man......
You are indeed a lucky man......![]()
LOL, I guess that grandma doesn't browse the forum, right?!?![]()
and the reason for overheating Bart?
All good info Bart, but I can't see the root cause in the symptoms. So, there was normally a loss of coolant after you topped up, but this did not continue to drain out, when the level got to a certain point. As far as you were aware, the coolant temperature was ok until you had a catastrophic loss of coolant, which caused the overheat, and the engine then hydraulic'd. So what caused the catastrophic loss?
Not sure Vas. Water in the cylinders would cause immediate hydraulic issue, but I don't think there would necessarily be coincident overheating. So on the intake stroke, the cylinder was sucking in water? So it would immediately stop. I would be concerned that the rebuild did not fix the original problem, until I understood the original problem. I know very little about these engines, so apologies if I am showing my ignorance here.crack in exhaust manifold got bigger and flooded pistons (errr, cylinders...) P?
shall we guess that coolant goes through the exhaust manifold in order to cool the turbo or something?
V.
V.
I would be concerned that the rebuild did not fix the original problem, until I understood the original problem. .
Quite right Bart. You need a pair of reliable motors after all the hassle you have suffered.exactly !
the rebuilder has good intentions, and good hope for the repair,
I try to give him as much info as possible, and asc him to take all potential causes in to considerations,
I stalk him with all possible questions / comments , but alway's on a friedly and cooperive tone![]()
its in his and my own benefit that after the rebuild the engine is OK
i am still struggling with some of the logic here. So the manifold is cracked, and there is water in the manifold. How is this going to get into the cylinder? It can only enter through the exhaust valve, which is releasing the exhaust gas under pressure. How does the steam swim against this tide?Paul,
maybe crack increased while engine was running at displacement speeds, water "dripping" in the manifold, just boiling and disappearing to exhaust, no chance of getting in liquid form down to the pistons. Actually probably not even "getting" in the manifold, just gasses from the manifold getting in the coolant and boiling it in no time.
Loss of coolant large enough to run out of cooling power, hence overheating.
Bart, stopping engine, letting it cooling (gap/crack remains) water poured in goes straight down to cylinders.
Bart, trying to start to no avail.
That's an ideal scenario where coolant in cylinders doesn't result in bent con-rods or damaged block/crank.
How close would this scenario be?
cheers
V.
