Ocean Deep Shocks
Gludy
19 Aug 2001
Brecon, Wales
www.sailingvideos4us.com
My boat is out of the water and if I touch any metal parts such as light surrounds, ruddrs etc I am getting a hell of a shock.
Should boats out of the water be earthed? There is a main supply to it.
cliffdale
Falmouth Cornwall
Good job Trader dont make a steel hull boat!
Try putting a volt meter negative side to Earth and probe around with the positive end of the meter. See what the potential difference is.
Whilst on the subject, why are my anodes only lasting 4 months?
Cliff
PhilF
18 Jun 2001
In a state
I have never earthed mine when it is out of the water with the mains plugged in, sounds wrong and a fire hazard too, be careful
rickp
10 Nov 2002
New Zealand
Do you have an RCD on the boat? I wonder if this is the source of your electrolysis problem....
Definitely something to get to the bottom of whilst the boat is out.
Rick
andyball
1 Jun 2001
that's a good point Rick - I wondered where the rcd was some time ago, finding just an over-current breaker where the shore-power enters the boat.
rickp
10 Nov 2002
New Zealand
Residual Current Device - turns the power off if there is a leak. Put simply, it 'trips' if the current out of the live does not match that coming back via the neutral - because if there is a difference, the power is going somewhere else - and thats not good(TM).
Rick
brianrunyard
30 May 2001
Poole, Dorset. UK
homepage.ntlworld.com
A residual current device (RCD), or residual current circuit breaker (RCCB), is an electrical wiring device that disconnects a circuit whenever it detects that the flow of current is not balanced between the phase ("hot") conductor and the neutral conductor. The presumption is that such an imbalance may represent current leakage through the body of a person who is grounded and accidentally touching the energized part of the circuit. A shock, possibly lethal, is likely to result from these conditions; RCDs are designed to disconnect quickly enough to prevent such shocks.
Pete7
11 Aug 2004
Gosport
Your getting mains electricty thoughout the boat /forums/images/graemlins/blush.gif I would up plug it, tell Trader before someone electricutes themselves and book into a B&B. There is a public footpath through there yard, anyone could be a bit too nosey and get quite a shock
cliffdale
Falmouth Cornwall
We are assuming it is mains. Its difficult to tell whether it is alternating current or direct current without an oscilloscope. What happens when you disconnect from the mains supply?
There are plenty of ways 12.8v can be generated up to 105v
thailand69
3 Dec 2006
West of Les Écrehous and North of Les Minquiers
It is NOT normal.
I don't know much about electrickery but if this was my boat and she was plugged into the mains then this would be the first thing I switched off. I would also be minded to take off any expensive electronic toys.
Apart from the risk of Electrocution I would also assume a possible fire risk.
I would get a proffesional in before she catches fire, unless............ /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
steverow
13 Dec 2002
Warwick. Boat in Swansea
Paul,
This looks like some kind of phase problem with the shore feed.
I'm sure Chris will know the exact answer.
It is however very dangerous so stay off the boat for now until trader have fixed it.
I mean that by the way...you can easily electrocute yourself or Lesley under those conditions.
halcyon
20 Apr 2002
Cornwall
Just a point, 105 volt can kill you, if you have a little bit of current.
From my days of designing fork trucks 70 volt is the upper safe voltage, though I do not offer warrenty.
105 volt sounds like half wave mains volts.
Un plug it.
Brian
steverow
13 Dec 2002
Yes it will be but I suspect the supply to the yard will be three phase...so it depends on how the supply has been wired.
Having had this sort of problem before at school, 105 volts sounds just about right for a phase issue.
