Robin
Must have been an exciting ride. But you had the right boat for it.
A rather different memory of the Theodora/Kindly Light stands out for me.Do you remember her heavy, gimballed aloon table? Now, of course, gimballed tables can be disorientating because your brain "corrects" what you see according to expectations and it appears that they, and not the cabin around them, are tilting.
We were sailing in Southampton Water with a party of dignitaries on board. I think the OYC was trying to extract money from their wallets. Flat water, but a fair bit of wind and we were heeling significantly. Lunch was prepared - salads, cold meats, cheese, pickles and chutneys, bread, butter, plates, cutlery - all laid out ready on the saloon table. A veritable groaning board.
Then someone came below and, instinctively, without thinking, stretched out a hand and put the table straight......
You should have seen the mess! (No, it wasn't me wot dunnit)
The table is still remembered well. It would stay level as the boat heeled, but it had limit stops. When it reached the stop and the boat heeled more, the bit that your eyes told you was the highest side was in fact the lowest side, so if you put a cigarette or something else round on it then it would roll 'uphill'. We used to do that to one crew member that suffered from sea sickness, worked every time.
I also remember standing in bilge water legs astride the propshaft to wind the clutch in/out, and taking plugs out of the running engine to clean them. The engine was a four cylinder with 1 & 3 and 2 & 4 firing together, with decompression valves on each, so you shorted out a plug, decompressed the cylinder, removed the spark plug, cleaned it and replaced it (fun getting the threads to engage with the piston pumping up) and hopefully it now firing again. The cleaning needed because the engine was running on paraffin, having first been started on petrol. Then there were the kapok ex MOD lifejackets that sank when we dropped them in the water and the DIY harnesses we made by putting a bowline in the end of a bit of rope. Elf and Safety would have loved it!
