mrming
Most of the lights in my Fulmar have now been replaced with modern units with LED bulbs.
There’s still an older fitting in the heads, and I’m looking for a suitable replacement.
Q1) The current item is one where you twist the lens to turn it on / off. The switch has become unreliable and so I would like to replace it with a fitting that has a normal switch. However, it occurred to me that the twist design might be for a reason. Is it possible it was designed for use with damp hands?
Q2) I’m looking for a small-ish surface mount 12V light, with a proper switch (or a pull string), and ideally with a bayonet socket that can take a LED bulb, rather than an integrated LED bulb that can’t be replaced. I’ve tried the smallest item from Force4 (with integrated bulb), but ended up returning it as it was more suitable for illuminating a prison yard. Not marked as such on their product page, but it turned out to be cool white and about twice as bright as needed. Does anyone know a supplier who might have something suitable? I’ve tried 12V planet but they don’t have the right thing unf.
Any tips greatly appreciated!
